Will lowered rack mount reduce bump steer?
I don't know what your asking, but offset steering rack bushings will move the rack higher, to level out the tierods more, which will reduce bumpsteer. If you lowered your car more than 1.5" then you will probably need a bumpsteer kit, which is just tierod ends with spacers.....
Well, the thing is, I'm changing my complete front end. I'm swapping in a aje k-member/a-arm/coil over kit...and for some reason, I asked to drop the rack mounts by 3/4 inch. Now, I am installing a 99 v6 spindle assembly which does lower the tie rod mounting location a little (I think)...but hopefully I did not make a huge mistake by asking him to lower the rack location. I do believe I still have time for him to change it, as I just ordered the kit yesterday. I do plan on lowering her a tad...maybe 1-1.5" max.
