I can tell you that with shortie headers, the h-pipe from a 95 won't fit without modifications because the hangers are not correct and the air pipe is in a different location. I would assume you'd run into the same problem with the hangers on the mid pipe.
It will fit but the hangers won't work so go ahead and cut them off. Get some heater hose for the air pipe. I believe it's 3/4". I cut the hangers off 87-93 mid pipes because they're a pain in the neck to line up. The UPR X pipe doesn't even come with them.
