Exhaust Will Piecing Together This Exhaust System Work?
Venom351R
4,548
38
98
43
MAINE
I really want to run a borla cat back system. It sounds awesome and I have never run borla before. Problem being the cheapest kit I can find is $640....ouch.
But I remembered something that does help me out. I still have the flowtubes from my Dynomax superturbo's that I can take off and I still have the tail pipes from my Mangflow system when I had magnapacks. Should I be able to just buy the Borla PRO XS Mufflers, use the flow tubes from the other set up, and use the magnaflow tail pipes and have this all actually work? The way I see it while each exhaust system is slightly different they still have to follow a basic format for how it will all connect and where the exhaust hangers are. If I just buy the mufflers and the bad ass borla tips the cost comes out to $513 so Ill be saving $127 and still get the same system as I would have if I just bought the kit ( at least I'm hoping)
Thoughts? Suggestions? Bad Idea? Forge ahead and buy parts?
  • Sponsors(?)
ProKiller
3,064
14
78
PA
Visit site
pics of said parts you have? aren't the XS mufflers a offset muffler where as the magnapacks are a straight through, so not sure how those would really match up.
Venom351R
4,548
38
98
43
MAINE
You can get offset or center inlet/outlet with the borla mufflers. I'll get pics when I get home later today. I was off on my math the mufflers and tips would be $350 not $513 not sure what I did there. I'm ok with going down to 2.5" for the cat back I have seen lots of combos with 1 3/4 long tubes a 3" mid pipe and 2.5 cat back
WhiteCobra95
5 Year Member
May 2, 2006
304
25
39
Mixing and matching exhaust system parts rarely works out. I've tried it several times and found that every aftermarket company does things just slightly different, and nobody quite matches the stock locations. Unless you have welding/fabrication ability or a friend at an exhaust shop who can help, it might be worth the money to just buy the whole borla system. The shops here in Detroit charge an arm and leg to do custom exhaust work. If you can't get a good deal on the work, you're probably not going to be too far off from just paying for the complete system once you total the muffler price along with the shop charge to cobble it all together. (The other thing to watch out of if you do take it to a shop is that they will probably bend your pipes if necessary to make it fit right.)
Others may disagree, but combining different parts has never worked for me.
Venom351R
4,548
38
98
43
MAINE
well thats kind of a downer but I'm sure your right. Plans kinda got thrown off anyway b/c I cant even get the flowtubes out from the dynomax mufflers. They were spot welded on and I cut through the welds with the cut off wheel but the tubes still wont come out of the mufflers. Its to much of a hassle, I mean If I really wanted to get them out I could but its not worth the effort. Guess I'll be stuck with paying full price for the borla kit or breaking down and getting a cheaper kit
revhead347
My mission is to out curmudgeon you
8,247
1,125
214
40
Acworth, GA
I mix match exhaust systems all the time. Stuff by the same manufacturer hardly ever fits together right, and your odds with mix match parts are about the same. I'm not sure if $127 savings is really worth it though. Maybe if you could find a better deal on the mufflers. I would say go ahead and try to reuse the tailpipes, but the last time I checked basic Walker 2.5" flowtubes were $54 on Summit. It's probably not worth cutting down the welds on the old ones to save $54. It's a lot of work with a grinder cutting those welds back. Oh, and don't cut it with a sawzall, and rig it back together, it's going to look like ass, and not function as well. Take a grinding wheel, and grind the weld back on your old mufflers parrallel to the pipe. You should eventually get to the point where you can hammer the pipes back out.
Kurt
Venom351R
4,548
38
98
43
MAINE
Ive pretty much decided not to do this. Ive learned and seen enough over the years to ask about something online, get answers then do the opposite only to get the results that everyone else said you would get
Venom351R
4,548
38
98
43
MAINE
I have not come across anything that sounded better then my Magnapacks and Bassani Catted X pipe it was just mean. I hate the sound of chambered mufflers, they are raspy and drone
revhead347
8,247
1,125
214
40
Acworth, GA
I lived in Daytona for 8 years so I've heard more Harleys than most. It was just comparitive. I associate the sound of a Harley to a poorly tuned non performance machine, like a canal boat. That's how Flowmaster's make a Mustang sound.
Kurt
notch351
110
I had long tubes with full mac exhaust on my old ride and it sounded great wish my current stang sounded as good. have to wait for the funds for long tubes
Thread starter Similar threads Forum Replies Date
Hoytster Progress Thread Darn Stock Block Problems - Putting together the pieces Fox 5.0 Mustang Tech 79
G What is this plastic piece called? Holds together throttle and tv cable 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
Kdubslugga I need to piece together a fuel system for about 700 extra RPM. Fox 5.0 Mustang Tech 17
hotstang_46 Looking to Piece together Big Brake Kit, Need Brake Guru's 1996 - 2004 SN95 Mustang -General/Talk- 42
R I have began to piece together my supercharger..have some questions 1996 - 2004 SN95 Mustang -General/Talk- 6
T piecing together a vortech 1994 - 1995 Specific Tech 5
fivespeedsteed my dilemma: m2300k or piece together 99-04 non cobra pbr stuff 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 38
Snikt89GT Starting to piece together 5-lug conversion 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 34
G A/C pieced together Classic Mustang Specific Tech 5
ROLLIN5.0 Piecing my stereo system together for my 95 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 12
Black95GTS piecing together combo, first step, opinions wanted 1994 - 1995 Specific Tech 29
S Buying a n20 bottle and piecing together the rest. What all is needed? 1994 - 1995 Specific Tech 9
95strokerPSU Piecing Together Suspension...Questions 1994 - 1995 Specific Tech 11
BlackFox5.0 Would it be cheaper to piece together a supercharger? Fox 5.0 Mustang Tech 2
L WTB/Trade Bolts for 2002 mustang exterior pieces Interior Exterior Parts 1
Saberdemon Mustang to fear 1 piece headliner 1965 - 1973 Classic Mustangs -General/Talk- 16
9 V-8 Motor mounts and related pieces 1974 - 1978 Mustang II Talk & Tech 2
tsiemens Whats this? Next to the torque box. Looks like 2 replaceable pieces 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 38
D Best 1-piece headlight fitment? 1994 - 1995 Specific Tech 1
James V Fox Why is this one piece painted like this? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
a_bartle One piece headlights for '94 to '98 Mustangs.... 1996 - 2004 SN95 Mustang -General/Talk- 0
SN65 For Sale 17" Forgline 3 piece rims with Toyo RA-1 tires Wheels Tires Brakes 0
C What is this piece? 1996 - 2004 SN95 Mustang -General/Talk- 1
Woody3882 Please help me Identify what this is for 65 exhaust manifold piece 1965 - 1973 Classic Mustangs -General/Talk- 3
fredfifty Fox Thermostat Fell Apart - Pieces Fell In Coolant Paasages 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
lenko WTB/Trade WTB Saleeen Series VI.5 Mustang Supercharger Housing 2 piece like below for 2006 Mustang located in Lethbridge, AB Canada. Other Classifieds 0
denny j sayers The Clutch And Assist /my Top Plastic Piece Broke Malking New One Trying To Get Length On The Stem F The Welcome Wagon 5
3 One Piece Headlights Fox 5.0 Mustang Tech 9
U Interior and Upholstery Broken Seat Track Piece. Seat Rocks Back And Forth 1996 - 2004 SN95 Mustang -General/Talk- 1
Mstng93SSP One Piece At A Time....just Like Dave! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 105
J Does A 1993 Mustang Gt Have A 1 Piece Or 2 Piece Fuel Eccentric? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
James V Fox Can Someone Tell Me Where These Pieces Go? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
K Expired Speedform Agent 47 Retro-style Race Mirrors, 3 Piece Roush Style Spoiler, Custom Sub Interior Exterior Parts 0
87hatchirv Expired Pace Car Rear Spoiler/3 Piece Interior Exterior Parts 1
D Help Identifying Weatherstrip Piece SN95 4.6L Mustang Tech 0
General karthief Fox One Piece Head Lights 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 28
J Engine Found Metal Piece In Cylinder... What Is It? SN95 4.6L Mustang Tech 8
WonkeyDonkey Expired One Piece Headlights Fox Body Mustangs For Sale (1979-93) 0
S One Piece Floor Pan 65 Mustang 1965 - 1973 Classic Mustangs -General/Talk- 7
C SOLD 2015 Mustang 5.0 Gt 6-speed Automatic 1 Piece Aluminum Driveshaft 3.5" 1000hp Drivetrain Parts 1
YadiStang I Lost A Piece To My Convertible Top Latch....what Is It? 1965 - 1973 Classic Mustangs -General/Talk- 7
84Ttop Has Anyone Installed A One Piece Driveshaft? 2015+ (S550) Mustang -General/Talk 0
M Mystery Plastic Piece From Gas Tank Hose, Need Part Name And Number. 1996 - 2004 SN95 Mustang -General/Talk- 0
K Fox One Piece Headlights 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 73
Five_Liter_Chive_Eater Steering Column Missing Trim Piece 2010 - 2014 Specific Tech 1
A Triple White Fox Body Trim Piece 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
Jeremy Batchelor Brake Pad Change...what Is This Piece? SN95 4.6L Mustang Tech 4
1 SOLD Oem Black Interior Pieces From 93 Lx Hatch Interior Exterior Parts 9
90lxwhite Fox Rear Main 1 Or 2 Piece 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 14
sixt9coug Engine Does Anybody Make A Distributor For Our Cars That Isn't A Piece Of Crap? 1994 - 1995 Specific Tech 16
