Will the stock computer work with this?
djharr
10
I am putting together a package that is made up of a Gt40 upper and lower intake, the Twisted Wedge street & track heads running about 10.5:1, and a 347 stroker setup in my engine. Is the stock EEC-IV going to be able to handle this much power? Undoubtedly I will have to put new fuel injectors in to allow for more fuel into the system, and I have heard people say that all that extra power runs the computer beyond the edge of where it is intended to go in stock form.
Is this an old wives tale, or should I be budgeting for some new EFI hardware? If I need new hardware, what are some of the options available?
David
David
I'll take a stab at this. I'm not the best EFI guy but here's something to think about. The A9L is a great computer when tuned right with your combo.
If your going to run 24 pound injectors you might think about using the X3Z computer from a 93 Cobra. It's the only computer that is the correct way to use them and you would also need the MAF from the same car.. Yes you can get the A9L to work with them but you have to buy a MAF meter to trick the computer to think it is programed for 24pounders. Some 93 Cobra owners even have removed there X3Z for the A9L and were very happy.
But from your combo you might even think bigger injectors then just the 24's. maybe a step or two bigger.
It will probably run with the stock computer, but not well.
Go spend $300 on a Moates.Net Quarterhorse and go spend some time on eectuning.net - then tune it yourself. It's really not that hard.
The EEC can handle way, way wilder setups than what you've got.
Good luck....
