Will These Wheels Fit?
  • Thread starter Thread starter 90' LX 5.0
  • Start date Start date Dec 5, 2006
9
90' LX 5.0
59
  • Dec 5, 2006
My 1991 LX 5.0 was converted to a 5 lug setup by the previous owner. I want to buy some new wheels. The ones I am looking at are for a "94 to 2005 mustang" They are 5 lug. Will they fit?
Cwalk
78
Virginia Beach, Va
Dec 5, 2006
  • Dec 5, 2006
yes 94-04. dont know about '05 i think the offset is different. So I wouldn't go with 17x9's from an '05. I could be wrong. Won't be the first time.
Snikt89GT
264
Deland, Florida
Dec 5, 2006
  • Dec 5, 2006
Depends, does it actually have SN95 spindles, or the cheesy lincoln rotors?
9
90' LX 5.0
59
  • Dec 5, 2006
Im not sure.. Is there a way to tell? Its got drums in the rear.
The wheels on it now are 17's. They look like 96 cobra wheels, but im not sure.
Im looking at a set of 4 Gunmetal Saleen pony wheels. 18X10 and 18X9. Could get all 4 for about 420 bucks, so its a pretty good deal.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Dec 6, 2006
  • Dec 6, 2006
If you have a sealed bearing Hub up front then you have the SN95 Style and will be able to fit all the factory wheels. It sounds like you may have the Cheesy Lincoln set up in which case your wheel selection is very limited.
9
90' LX 5.0
59
  • Dec 6, 2006
Sorry for being such a noob, but how do I identify a sealed bearing hub?
Amazing how i completed an AOD to TKO swap, and yet still know nothing about a lot...
I
iwashmycar
20+ Year Stangneter
Apr 7, 2004
1,236
Columbus, Ohio
Dec 6, 2006
  • Dec 6, 2006
it depends if the rotor comes off over the studs, or the studs are part of the disk with a big dust-cap in the middle. The one with the studs attached is the cheesey Lincoln conversion, which i have on my car. The 96 cobras will work with this, but there are many other factory wheels that will not directly bolt up due to that dust cap bein in the way
stangbear427
2,401
New England
Dec 6, 2006
  • Dec 6, 2006
Not to run off on a rabbit trail, but I love the look of those tri-bar wheels on your red GT. Wanted to use the same ones to 5 lug my '91, which never did happen. Nice smooth looking car... I'm glad to hear you wash it.
9
90' LX 5.0
59
  • Dec 6, 2006
So i have to take the wheel and the dustcap off to tell?
Im at work now... so i will do that when i get home if thats what i need to do...
Thanks for the help.
Edit: Well acutually the fact that I can see the big dust cap kind of gives away the fact that I have the Mark VIII setup. Correct?
9
90' LX 5.0
59
#10
  • Dec 6, 2006
  • #10
Ok so assuming that i have the cheesey style setup with the ranger axles and the mark VIII rotors....
I found a set of SN 95 spindles for a reasonable price. So if I buy these will i also need new axles? If so which ones do i need? and where can i find them?
Also will the 5 lug drums on the back fit with the 18X10's?
I have my heart set on these wheels and, the SN 95 setup would be an upgrade anyway...
Chuckman
GTFO you fat, heavy bastard
1,604
1,002
173
st. louis, mo
Dec 6, 2006
#11
  • Dec 6, 2006
  • #11
the ranger axles will work fine with either spindle, so youre good on that, and the drums will fit just about any wheel, theyll just be ugly. if youre going to do sn95 spindles, i would also do either a 99+ rotor/caliper or cobra all the way around. there are brackets around that let you use the axels you have now with the newer rear discs.
9
90' LX 5.0
59
#12
  • Dec 7, 2006
  • #12
Sounds good. So ill buy the new spindles and that should be fairly straight forward. Will my stock brake lines work ok with the new spindles? Anything else to worry about?
thanks
trbkrb
1,976
Houston, TX
Dec 7, 2006
#13
  • Dec 7, 2006
  • #13
Read http://sn95brakes.com , the 5 lug section. Matt covers all the things you need for the front and rear conversions on his website. Depending on what you change to, there are many other things you need to upgrade (MC, PV, Ebrakes, etc if going rear disc, booster, and more)
Mustang5L5
Mod Dude
Feb 18, 2001
43,382
18,125
224
Massachusetts
Dec 7, 2006
#14
  • Dec 7, 2006
  • #14
Depends....what are the wheels?
That's like asking if a V8 engine will fit in a Mustang
J
Wheels-Tires Need Some Help - Brakes Upgrade/Wheel fitment
  • jaygee15
  • Dec 8, 2025
  • 3 4 5
4K
Fox 5.0 Mustang Tech Oct 6, 2026
jaygee15
J
G
Engine ECU Question
  • GeorgeE
  • Oct 12, 2026
Fox 5.0 Mustang Tech Oct 19, 2026
JD1964
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
M
Rim suggestions
  • mason5.0
  • Sep 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Qtrhrse23
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Oct 27, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 27, 2026
dmw_4814
D
