will this make a difference
  • Thread starter Thread starter 89five0
  • Start date Start date Oct 10, 2004
89five0
50
  • Oct 10, 2004
well my mods are in my sig and i was wondering if a 65mm throttle body will make a difference at all. I was just wanting to know if this will help if if there will be a noticable difference. any brands reccommended? thanks
Trey
speedracer238
141
Clawson, MI
Oct 11, 2004
  • Oct 11, 2004
yes
1986LX2002
317
  • Oct 11, 2004
Accufab.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Oct 11, 2004
  • Oct 11, 2004
Go ahead and get the TMOSS lower and slap a 65mm Accufab TB and EGR plate, don't forget an upgraded MAF like the C&L 73 or 76mm unit. You'll feel a difference in throttle responce and the car will breath a lot better.
C
criticman
723
Rome, GA
Oct 11, 2004
  • Oct 11, 2004
Yes - and since you seem to like BBK...stick with it
jb89coupe
416
CT
Oct 11, 2004
  • Oct 11, 2004
If you're going to stick a bigger tb on the stock intake you *really* should port-match it. The stock intake port is only 60mm. If you stick a 65mm tb on a 60mm opening you won't really see any benefits, if anything the turbulence from the air hitting a hard edge might cost you some power.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Oct 12, 2004
  • Oct 12, 2004
Everyone I have ever measured has been 63mm - but it is still a good idea (and easy to do) to open it up to 65-67mm.
1Slow5oh
92
Bartonville, IL
Oct 12, 2004
  • Oct 12, 2004
How is it easy to open the intake to 65-67?
Can I do it myself?
M
mooktank
237
  • Oct 12, 2004
yeah buy a porting and polishing kit from summit if you want it realy smooth otherwise just use a grinding stone on a die grinder or dremel tool. Just open up the intake by removing aluminum so its just as big as the TB.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Oct 12, 2004
#10
  • Oct 12, 2004
  • #10
If you use a stone, be sure to use lots of spray lube in it to keep the aluminum from laoding up the stone pours.
donsbad68
Immensely Educated
Jan 4, 2003
838
Oklahoma
Oct 12, 2004
#11
  • Oct 12, 2004
  • #11
yes and I too like BBK/Edelbrock
Suspension Quad shocks
  • keel
  • May 20, 2026
Fox 5.0 Mustang Tech Sep 2, 2026
AeroCoupe
Engine Crankcase vent tube “relocation”?
  • Mcmahst
  • Nov 20, 2025
Fox 5.0 Mustang Tech Dec 20, 2025
manicmechanic007
Supercharger and What else do I need? 1990 Saleen Vert 5spd
  • AlbertaGolfer68
  • Aug 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
General karthief
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
