- Jan 30, 2011
- 2
- 0
- 0
I have a 1986 Mercury Capri (close enough to a mustang) that had a 302 H.O. in it but that motor threw a rod at 250k miles. So after restoring the chassis and prepping it for a new powerplant, I obtained a 289 with forged crank, rods and pistons. These pistons are dished flat tops, the heads are 54cc 1.74"/1.50". The valves/springs are stock. I am in the process of rebuilding it from the ground up, but I am stuck with a very difficult decision...
Could I install my F-303 roller cam in this block if I drilled and tapped the block to accept the lifter baffles to retain the roller lifters? And would the lift and duration of the cam interfere with any other parts of the motor (such as maxxing out valve springs or colliding pistons with valves)? I am installing the 5.0 H.O. fuel injection intake on this motor as well, so if this setup works, what do you think of this setup in a Capri/Mustang with a 5 speed manual and stock rear gears(2.73 I think)?
