wilwood Brake line question
Npower
Camarillo, Ca
Do you guys know if there is an adapter to go from the hard lines on the rear end of my 1993 cobra to -3an male. I have wilwood calipers and the brake lines in the kit are -3an female on both ends. I have a 90 degree adapter to go into the caliper but I need to adapt the hard lines on each side of the axle housing so it will screw onto the -3an female wilwood brake line. :shrug:
Any help would be great!!!
or do you know what the tread type / pitch is on the rear hard lines where it connects to the oem rubber lines?
