Windage Tray 351W
  • Thread starter Thread starter jaketuff
  • Start date Start date Jun 22, 2004
jaketuff
159
Westchester, NY
Jun 22, 2004
  • Jun 22, 2004
Hey guys,
Who has installed a tray on their ride? I need the torque specs for the mains on the 2 bolt main 351W. I have the 385 Crate Motor btw.
Of those running a tray... noticeable gains in HP? Oil pressure now has got to be monitored like a hawk, as less saturation meets the crank.... or is this a total hoss sh1t myth?
Thx!
OUT
SlowGT
826
Columbia Co, PA
Jun 23, 2004
  • Jun 23, 2004
I never used a windage tray with hopes of improved HP. I always put them in to help control the oiling.
I don't believe it's a myth. Swing your arm around in the air. Now get in a pool and put your arm through the same motions in the water. Get the picture. Kinda how your crank behaves in free air VS sloshing around the oil.
jaketuff
159
Westchester, NY
Jun 23, 2004
  • Jun 23, 2004
To control the oil right.... but wouldn't it be safer in your perspective to have more oil sloshing and saturating the crank... ?
With your example... don't you think that there must be a slight gain in HP as the crank doesn't have to push thru the oil sloshing?
Any idea of the TORQUE Specs???
Thx!
OUT
SlowGT
826
Columbia Co, PA
Jun 23, 2004
  • Jun 23, 2004
No, it wouldn't be any safer with oil sloshing around on the crank. It doesn't do a bit of good there. The oil needs to be in the oiling system where it'll find it's way to the crank/rod journals. It's certainly not going to splash in there.
Maybe my example was a little exaggerated. The HP gain would be insignificant for street purposes. Start turning 7000+ rpms and then maybe you'll start finding a couple extra HP in the high end. That's why you'll see real serious race motors running dry sumps & pulling a vacuum on the oil pan.
As for torque specs, these are the only #s I've got handy.
For a 95 Cobra R (351w): Main bolts-->105. That's assuming stock fasteners installed with 30 weight oil. That number will change if you're using an upgraded fastener such as ARP. ARP has a listing of torque specs for their fasteners on their website if you need them.
Engine Cam idle and timing questions - big cam, little knowledge
  • Justin87
  • Jul 6, 2021
12K
Fox 5.0 Mustang Tech Jul 31, 2021
Middleagecrisis
M
J
351w swap in 2004 questions (set up like a 95 Cobra)
  • jonathansw1601
  • Mar 24, 2018
  • 1994 - 1995 Specific Tech
3K
1994 - 1995 Specific Tech Jun 28, 2018
jonathansw1601
J
J
  • Locked
SOLD '95 Cobra GR40 Griggs w/410ci forged stroker
  • Jer
  • Oct 24, 2018
9K
SN95 Mustangs For Sale (1994-04) Jan 12, 2022
Jer
J
427w Engine Build
  • LuckyM95
  • Nov 12, 2016
17K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 11, 2016
LuckyM95
N
SOLD Supercharged 1989 SSP Coupe $13,500 obo
  • notchlubber
  • Jul 17, 2018
13K
Fox Body Mustangs For Sale (1979-93) May 28, 2020
notchlubber
N
