Window leaking.
Barjam
38
My windows are leaking right around the rubber window boot (right behind the mach 460 speaker pod). What is the fix for this? New rubber seal (if so where is a good source for these)? I tried putting some silicon on it and that just made it worse.
Thanks
Barker02GT said:
Mine is actually doing the same thing. Washed mine over the weekend and noticed it's leaking on both sides in the same place. I would be curious to know as well....
It looks like frameless windows are adjustable. I think I will get some rubber adhesive to fix the tiny tear I have in mine and try to adjust the window.
I will let you know if I have any luck.
I've got the exact same problem on both sides. This seems to be a basic design flaw. It only does it with pressurized water (i.e., when I wash it), and not, thank God, when it rains. It's just a little bit of water in my case, so I just wipe it up as I go. But obviously, I'm a little worried about the speaker pod's integrity over time.
