  • 1994 - 1995 Specific Tech
Window motor installation help
  • Thread starter Thread starter deadly97snake
  • Start date Start date Jul 19, 2004
deadly97snake
592
Manchester, NH
Jul 19, 2004
  • Jul 19, 2004
I had to get a new window motor for my 94 gt passenger door. The problem is, I cannot get the motor all the way in, it like goes half way or something,what is the proper way to put it in,has anybody had to do this,it looks so easy but i just cant get it all the way in,i can even up and put in the top and right screw but i cant get the bottom one in. It looks like the "teeth" on the motor and the teeth on the door won't line up.
thanks, Mike
AZ95GT
326
Arizona
Jul 19, 2004
  • Jul 19, 2004
Check out the FAQ section, I believe there is a step by step on how to do it with pics and everything... Good luck
deadly97snake
592
Manchester, NH
Jul 19, 2004
  • Jul 19, 2004
been there, it's just the install and nothing about what to do if it dosen't "just go back in, and reverse steps" Thanks though.....Mike
AZ95GT
326
Arizona
Jul 19, 2004
  • Jul 19, 2004
Is it possible you got the wrong motor??
AznStanger3v
2,026
Northern VA
Jul 19, 2004
  • Jul 19, 2004
mine just slipped right in when i did it. try playing with it a little.
deadly97snake
592
Manchester, NH
Jul 19, 2004
  • Jul 19, 2004
no, it's a perfect match
deadly97snake
592
Manchester, NH
Jul 19, 2004
  • Jul 19, 2004
was your window down while you were installing the new motor? mine is up, but I can lower it with a screwdriver, should I get it all the way down? I lowered it a little to see if it would help. maybe I need it all the way down
AznStanger3v
2,026
Northern VA
Jul 19, 2004
  • Jul 19, 2004
nope, it was all the way up. try adjusting it with your screwdriver.
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Jul 19, 2004
  • Jul 19, 2004
What brand and what's the part number?
H
hiattwl
145
Cullowhee, and Andrews NC
Jul 19, 2004
#10
  • Jul 19, 2004
  • #10
Try hooking up the motor, and using the switch to bump it until the gears mesh. This worked for me, because when i bought my GT, both motors were stripped out, and I rebuilt them with 1/4 inch nuts to replace the stripped out parts inside the motor.
Wayne
deadly97snake
592
Manchester, NH
Jul 19, 2004
#11
  • Jul 19, 2004
  • #11
OK I put the motor in. It seems like it is not fully inits place but I got all 3 bolts in. Now I lowered the window and when it reached the bottom the window tried to keep going down. It made some loud banging noise when it reached the bottom. Also it made another "bang" when I was raising the window and it got half-way up. It went up and down but not smoothly. Anybody experience this?
deadly97snake
592
Manchester, NH
Jul 20, 2004
#12
  • Jul 20, 2004
  • #12
To the top!
H
hiattwl
145
Jul 20, 2004
#13
  • Jul 20, 2004
  • #13
both of my windows did this as they were tearing up. It may not be the same, but you never know. There's little plastic bits inside window motors that are designed to break in the event someone's head is in the window. These motors put out quite a bit of torque, and they're there for safety. Now, it sounds as if they're breaking. It starts out as random bangs, and then it starts shredding these 3 pieces of plastic. As they shred the window will sometimes go up, with help, and go down, with help, it just get's worse. You may be experiencing this, however, you said you got new motors, but were they from another car, or actually new. Take out the motor, remove the cover that is on the side where the gear comes out, and inspect them. Let me know, and if there is a lot of plastic in there, i'll tell you how to fix it.
Wayne
deadly97snake
592
Manchester, NH
Jul 20, 2004
#14
  • Jul 20, 2004
  • #14
Wayne
Thanks Wayne
I was looking at an old thread and I found someone with the same(well almost) problem as me.
SexyStang1994 said:
Uh... I found the problem... the stop fell off the window.
The actual STOP was laying in the bottom of the door.
How in the hell are you supposed to reattach this thing?
http://forums.stangnet.com/showthread.php?t=443175&highlight=window
I found a triangular piece of plastic on the bottom of my door. I have a feeling that it is probably the "stop". I will try and find out where it goes and put it back in. Hopefully it will make my window stop and not actually try to keep going down once it reaches the bottom of my door. After that I will try to find out why it makes that "banging" noise and why it studders once the window is halfway down the door. If all else fails I will take the new motor out of door again and open it up to see if the plastic is broken already like Wayne said.
deadly97snake
592
Manchester, NH
Jul 21, 2004
#15
  • Jul 21, 2004
  • #15
TTT
R
19 GT Window Motor Saga
  • Rcdgl
  • Oct 11, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Oct 11, 2026
Rcdgl
R
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
Help! Problem with replacment window regulator motor
  • TTSaleen
  • Oct 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 24, 2025
General karthief
Rear window failure
  • Moondog2178
  • Jul 22, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 22, 2025
Moondog2178
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
