Window problem.
  • Thread starter Thread starter Dbeck002
  • Start date Start date Dec 20, 2005
Dbeck002
710
South florida
Dec 20, 2005
  • Dec 20, 2005
I will try my best to explain my issue with as much detail as possible so that we can get to a solution fast.
My passenger side window does the following upon being rolled up. It goes up to about 3/4 way and then starts to slow down and dies. If i grab the window with my hand and pull it towards the rear of the car, it will rock back and then i can completely close it with the motor.
It is very odd, i dont know what is jamming it. I took apart the interior door panel and examined this 100 times. I greased everything in there with a grease gun. The jam is very akward, only when it gets to about 3/4 way there is something near the front (wear the mirror is) rubber seal that is jamming it causing it to rock forward, hence if i rock it backward it will unjam and go straight up.
This is annoying as hell, has it happened to anyone before?
PS. Sometimes it gets stuck in the down position and i have to take the panel off and loosen the 3 window motor screws and it will unjam down there. This is unrelated to the glass jamming part, but this happens too sometimes. Its been giving me hell lately.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Dec 20, 2005
  • Dec 20, 2005
if your window is rocking back and forth i would say you have a problem with the spot where the window mounts to the frame mechinism that allows it to go up and down. there are 2 large whit plastic pieces that go through holes in the window. if the rivets are loose or broken off this would allow your window to rock and bind up. check those.
I
Iand
50
Kelowna, BC
Dec 20, 2005
  • Dec 20, 2005
maybe your power window motor may be taking a craper? theres a website on how to 'freshen up' your power windows, unfortunatly i just reformatted my comp so i dont have it anymore.
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
Dec 20, 2005
  • Dec 20, 2005
I'd think the motor is going bad.
Dbeck002
710
South florida
Dec 21, 2005
  • Dec 21, 2005
i checked and you are right, the rivets that support the window are so loose. Everything is crickety down there. Maybe the motors are going bad too, dammit where can i get a new set. They are expensive too
W
wazazzle
618
In the dumpster behind McDonalds. WA
Dec 21, 2005
  • Dec 21, 2005
my buddy works on glass, including auto. mine did the same thing, getting stuck 3/4 way up. take the panel off, grease the tracking up. then with a scrapper shaped like a hook, run it along the inside window felt. it will help clear out any gunk jammed inside. Buy a bottle of 3M White Silicone spray, spray it along the inside of the window jam. Spray all up inside it everywhere. Then let the window slide up and down a few times. You will have to push it up perhap the first few tries, but eventually it should close by itself compeltely. Also spray the cable track too.
rd
3,316
63
109
Ocean Springs MS
Dec 21, 2005
  • Dec 21, 2005
Last two times I have had this, I have greased the tracks, guides, etc, and then just changed the motor. It fixed it both times. Windstar and F150. The Windstar would get stuck up, and the F150 would just barely go up.
Dbeck002
710
South florida
Dec 21, 2005
  • Dec 21, 2005
What is this spray? a lubricant of some type?
I think i might just need to change the motors.
PS. I loaded up the window with grease everywhere, gears, tracks etc... It helped a little but it still gets stuck.
Dbeck002
710
South florida
Dec 21, 2005
  • Dec 21, 2005
Do they sell high torque window motors? lol
I was thinking of taking mine to the dyno to see what numbers they put down.
gonna rebuild em with forged internals while theyre out!! woohoo...
HISSIN50
34
129
Dec 21, 2005
#10
  • Dec 21, 2005
  • #10
I use white lithium grease, which sounds similar to the 3M product (though I have no experience with that 3M product).
Good luck.
Front window issues
  • bruno
  • Nov 7, 2026
Fox 5.0 Mustang Tech 14 minutes ago
AeroCoupe
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
Help! Problem with replacment window regulator motor
  • TTSaleen
  • Oct 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 24, 2025
General karthief
R
2004 convertable help
  • realbkg
  • Jun 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jun 4, 2025
realbkg
R
Rear window failure
  • Moondog2178
  • Jul 22, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 22, 2025
Moondog2178
