Window Problem
FWIW, I've had 3 window regulators replaced under warranty on my 2004. That little rubber stopper at the bottom where the glass rests when down has come out about 4 times--the cause of the "clunk" so many people complain about.
Kilgore Trout said:
Update: the window does not go up or down anymore, it just makes horrible clicking and popping noises. This would be the regulator right?
hmm. i had a similar problem where it got stuck, i ended up having to cut out a portion of the door to get to the bottom roller rail and pop the roller back on the track, if you can, try to get a mirror in there and see if the roller is off the track first
-tomustang
-tomustang
Killy - Tom has hacked into my computer. :nonono:
:lol: ~J~
:rlaugh:
Anyways, thanks for the tips. I am going to pull it apart today, get the regulator at the Ford parts counter tomorrow, and install it tomorrow night. I need to pop rivet the window back on the regulator track to install the new regulator. Can I just use a regular pop rivet gun for this? I know I have to drill out the existing rivets. Is a special tool required to remove the regulator though? No way am I going to be cutting the door panel. There must be a way to avoid that and if it has to be done I am taking it to a shop...
I may order a regulator online though... When the catalog says "left" they mean the driver's side right?
svttech76 said:
sounds like the regulator to me killy. lucky for you the mustang regulators don't use a counterbalance spring. Those things were deadly I had more than a few buzz by my head when the flew off.
Wow, thanks for that info! I was reading my Haynes manual and there was a big warning about that spring. Glad to hear that I do not have to worry about death after all :D
I have never had the pleasure of doing a regulator in a mustang so I am not 100 percent sure but the ford service manual mentions nothing about a counterbalance spring in it. the regulators go so rarely on these cars and we see so few mustangs in the dealers that I never had to do one yet. I have done pleanty of regulators with a counterbalance in the older explorers and taurus and they all work the same so I will tell you how I did it in those.
Well If it does have a counterbalance then what you need to do is leave the motor on the regulator when you remove it fromt he door and put one end of the regulator in a vise then while holding the other arm of the regulator take the motor off and slowly move the regulator arm untill the spring looses tension.. install the spring in the new regulator the same way.. good luck and wear safety goggles.
What about the rivets that hold the bottom of the window onto the regulator track? Do they need an extra long drill bit to reach to and drill out for removal? And when reinstalling will the new regulator come with new rivets? Will a regular pop rivet gun reach in there or do I need a special one?
Before you drill the rivets out pop the pin out the center with a hammer and punch, then I use a drill to drill out the center of the rivets, a normal drill will work all you have to do is move the regulator to where you can access the rivets easier.
As for reinstalling it, I use a big handled rivet gun. since I neve done it on a mustang I am not sure a regular nosed one will work, you may end up needing a long nosed one.
Kinda off topic but I have a question about those rivets. I had to take two out in order to get my door handle off my truck the other day and they were are PITA x1000! But I didn't know I was supposed to punch the center first. :bang: Anyway, where do I get new ones and what type of rivet gun do I use to install them?
Where does one get a "long nosed" rivet gun??
you should be able to pick up the rivets at any automotive store like napa, advance, autozone, etc. they are called 1/4" window regulator rivets :) they have a special pin that splits the rivet as it pulls, so it spreads out more than a regular rivet. the door handle ones are the same, but a little shorter and usually black.
you can get the rivet gun from most places, you need the 1/4" "big daddy" rivet gun. ill google it and find a pic.
here is a pic of the rivet gun. if you are doing the door handles, you need a helper so you dont scratch the paint. have one person hold the nose, while the other pumps the handle. the regulator does not require a helper.
if you get the brand name one, MARSON BIG DADDY RIVET GUN, then its about $160. you can get a cheap knock off for about $15, but they dont last near as long as the marson one does. luckily for you guys, you wont need it very often, so a cheap one should be OK for you.
Well, I changed out the window regulator last night. It took about two hours and was fairly challenging but went pretty smoothly. The only mistake I made was forgetting to vacuum the crap outta the inside of the door. Now I have to go back in there and vacuum out the metal fragments and pieces of the rivets that I had to drill out in order to remove the window glass :bang:
I got the big heavy duty rivet gun capable of 1/4" rivets at Harbor Freight for $17.
The window regulator was $153 at the Ford parts counter (in stock) and had a $30 core charge.
The window glass rivets were $1.44 each and I got these at the Ford parts counter also.
The problem with the old window regulator was that some key spot welds had failed and the part just fell into pieces. Yay Ford :mad:
Here are some more pics I took of the window regulator change...
Here is the rear rivet that holds the window on the regulator. I drilled it out with the next size bigger from 1/4"
Here is the front rivet
The horizontal rail shown here is not part of the window regulator assembly so it is re-used
In order to get the glass out I had to remove the weather stripping on the inside and the outside of the window glass, that was kind of tricky...
Here is the stupid piece that fell off the regulator assembly. It is the gear that transfers the motor force to an arm that move the glass. The piece shown was spot welded on and the welds came loose so the piece just fell into the bottom of the door :nonono: When this happened the spring (yes there was a f'n spring :bang: anyways the spring was released and the regulator arms were fricking all over the place once I removed the glass and took the weight off :notnice: It was pretty dicey and I was afraid that my door would suffer exterior body damage when I struck the sprung tight mounting bolts of the window motor out of the door frame and the whole regulator assembly snapped inside the door :mad:
Anyways, the trim, window, and door stuff can be pretty tricky but I would do it again if I had to :nice:
Here is the new rivet gun I got for $17 at Harbor Freight
Here are the window regulator rivets compared to regular rivets
