my drivers window switches will not work wither window but the passenger switch does work? is this just the swithes or could be something else. anyway to test?
yeh pull the drivers window switch and test with a test light or meter. Test first for power coming out of he switch while pressd up or down. If thats good test ground. If you only have a test light hook the one end to the batter positive and test the oposite side of power the light should glow if yo have ground. Most likely gonna be a switch problem
I had the same problem on my 91 GT. The harness between the drivers door jam and where it goes into the drivers door had a broken wire from the door opening and closing. You'll have to open the wire loom or tape to find it. Common problem on cars with power windows. Check that if you don't have any power at the switch.
The break could also be inside the door and you will have to remove the door panel.
