  • SN95 4.6L Mustang Tech
window regulator update
  • Thread starter Thread starter driftin luke
  • Start date Start date Jun 9, 2009
D
driftin luke
18
  • Jun 9, 2009
Today I finally put in the window reg in my 98 gt. I reglued the bracket and glued on a support piece on each side of the bracket. Everything went together ok,I used bolts to re-install the window not rivets. There is only 1 problem the window only goes half way down then the reg seems to bind up. I'll look at it tomorrow but in the mean time any of thoughts or suggestions would be appreciated.The reg seemed to cycle ok when the window was not bolted to the regulator.Also when I took the old reg out the motor was positioned in the middle of the semi-ring gear so thats the way I installed the new one could that be the problem?
flstang65
1,484
135
94
SE Georgia
Jun 9, 2009
  • Jun 9, 2009
I am not understanding what you are talking about with the gluing. I have never had to re glue anything when changing out window regulators.
Rust under side window weatherstrip
  • swe13
  • Jun 5, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jun 5, 2025
swe13
Crank no start/no fuel pressure-pump runs
  • 4gwenddolau9
  • Sep 25, 2024
SN95 4.6L Mustang Tech Jan 27, 2025
TennMan
Help with window and possible engine
  • StefRena22
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2025
Willybill32
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
W
2012 Base Convertible Driver Side Power Window Will Not Work
  • wmmihail
  • May 25, 2024
  • 2010 - 2014 Specific Tech
2K
2010 - 2014 Specific Tech May 25, 2024
