window seals
  • Thread starter Thread starter tim_lemmy
  • Start date Start date Apr 16, 2008
T
tim_lemmy
94
  • Apr 16, 2008
anybody know where i can get a new weather strip for my sunroof? I can't find them at any parts place and the glass shops in my area say they can't get it. my sunroof has started leaking... at least i think it's the sunroof the water is coming in the trim above the doors and windshield, which is downslope from the sunroof, but it could just as easily be the windshield, either way the sunroof seal has major cracks in it and needs to be replaced. also how hard is it to re-caulk the windshield, i know it doesn't use a weather strip but i can't seem to get the metal molding off. is there some trick to getting it that i don't know? any and all help is appreciated.
thanks,
Blake
Beasty306GT
671
Oxford,Mass
Apr 16, 2008
  • Apr 16, 2008
you can get kits from 50resto.com mustangsunlimited.com...any place where you can buy parts pretty much
BUF92GT
12
Buffalo, NY
Apr 17, 2008
  • Apr 17, 2008
The metal trim is held on with clips. Just pull it straight down or use a flat screwdriver to gently pry it down a bit - then you can get it right under the clips and pop them off - there are three (left, center, right). I don't know if re-caulking the window will work if it is leaking - kinda like your shower - you either need to scrape all the old caulk out with a razor or actually pull the window and re-install with new sealant and everything. I would start with the sunroof - check foxmustangrestoration or 50resto. Keep in mind there are three seals on your sunroof - there is one on the glass, one that goes around the edge of the glass that seals it to the roof when it is inplace, and the third is around the inside lip of the sunroof opening. Check all three and good luck!!
T
tim_lemmy
94
  • Apr 17, 2008
BUF92GT said:
...you either need to scrape all the old caulk out with a razor or actually pull the window and re-install with new sealant and everything...
when i said re-caulk the window that's what i meant, but i'll start with the sunroof. also the water is not actually coming in at the sunroof it's coming through the trim above the doors and windshield so i want to cover all possibilities
Coupe Rear Glass Cost
  • AeroCoupe
  • Jan 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
AeroCoupe
Water leak from hatchback door
  • jeremyzcook82
  • Nov 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 25, 2025
jeremyzcook82
Sunroof Woes
  • TIGGER
  • Feb 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 3, 2025
Snakbytn1990
D
2006 GT Windshield Cowl install
  • Daddidio
  • Mar 12, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Mar 12, 2026
Daddidio
D
Paint and Body Re-sealing Rear Hatch Window
  • jeremyzcook82
  • Mar 6, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2025
limp
