Window?
  • Thread starter Thread starter dcurtis
  • Start date Start date Oct 7, 2007
dcurtis
688
Oct 7, 2007
  • Oct 7, 2007
if I tap the button for it to go up, it only goes up in intervals, so I have to tap the button 3 or 4 times to get it up all of the way, whats up with it?
SuperStang83
1,693
Boyertown, Pa
Oct 7, 2007
  • Oct 7, 2007
Why aren't you holding the button? If you are ut is most likely the window motor, or your actual window is getting hung up on things inside your door.
dcurtis
688
Oct 8, 2007
  • Oct 8, 2007
The windows are automatic in my car,both ways (up and down) all I have to do is tap the buttons for them to go up and down. Except the right one will stop a few times before it gets there, it goes down fine,just not up.
Fox Turn signal flasher keeps failing
  • keel
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
Differential noise over bumps
  • sharkrat
  • Apr 10, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jun 18, 2026
TPony
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
89 power window issue
  • Creomod
  • Sep 5, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 4, 2025
WillWho?
W
