Windows are flopping around on the tracks..
Mike86Stang
Advanced Member
Apr 11, 2000
10,296
Red Lion, PA
I finally got this 86 T-top up & running & tried rolling down the windows...
They go down fine, but coming back up they get cocked & stuck. The only way to get them up is to guide them back up with your hand.
Does anyone know how you fix it?
Thanks
Mike
Thanks
Mike
If you take the door panel off I believe there are two bolts that hold the window in place on kind of a scissor looking track. Check to see if those are loose. Once you get the panel off, and run the window up and down a couple of times, you will probably see what is causing it. :nice:
