Wiper and Blinker assembly replacement ???
1. disconnect negative battery terminal
2. Turn key to on position and push a thin punch up into a hole in the steering column directly beneath the ignition lock cylinder. You're pushing up on a button that releases the cylinder - when depressed, pull the cylinder out.
3. Use a phillips screwdriver to remove the screws securing the steering column cover, then pull off the top and bottom
4. Unscrew the multifunction switch from the steering column
5. Pull off the electrical connections from the switch.
Installation is the reverse. Good luck!
