wiper switch connections
ok the turn signals went out on my 87 gt. my old wiper/turn signal switch looks pretty bad anyways, so i figured what the hay. even if that doesn't fix it, i wanna change it out anyways. so after disconnecting the plugs in the back of the switch, some of the wires come out of the plugs and i don't know where they go. does anyone got a schematic or pictures that could help me out?
I have a wiring diagram set from an 89 Mustang. The turn signal should be the same.
attachment.php
If you need more, PM me your email address and I will send you a zip file with the whole wiring diagram set. It is too big to pass through Stangnet's email gateway.
thanx jrichker. i was able to verify all my wires were plugged in right. turn signals still don't work. i was lookin at my hazard switch and i'm wondering bout two things. 1st, there are two plugs that go into the hazard switch. hazards will still work when i unplug the smaller one. what is the function of that smaller plug with just 3 wires. 2ndly, when i pulled the smaller plug and looked inside the switch, i can't see any copper thingies sticking up where it plugs in. just 4 empty little holes where it looks like they oughta be. wonder if this has anything to do with my turn signal problem?
The Hazard switch only uses the top connector. The bottom connector is used by either an active Rear Window Defrost switch or Convertible top switch. It sounds like you just have the dummy switch for the bottom section.
ok i've got the classic hazards work but turn signals don't work problem. i went ahead and replaced both flashers. new wiper switch. new ignition switch. bulbs work fine when i hit the hazard switch so they're fine. runnin out of ideas. i should mention the turn signals went out slowly. they would actually quit for a while and then come back. now nothing
The turn signals use a separate set of contacts inside the Hazard switch. With the hazards off you should have power on the LB wire from the flasher into the switch and coming out on the O/Y wire at the back of the Hazard switch. If not, the switch is bad.
ok just tried something different. i pulled the plug from the back of the wiper switch. ran a jumper from the orange wire to the other wires on the plug. turn signals worked that way. does that mean the wiper switch is bad? its brand new?
Are you sure the new switch is for 87-89 model Mustangs?
A word of caution about multifunction switches is in order here. The multifunction switch (high/low beam, wiper, turn signals) are different for different years. 87-98 will work in any 87-89 car. The 90-93 switches only work in 90-93 cars. You can't put an early model switch in a late model car, nor can you put a late model switch in an early car.
Supposedly you can move the pins around to make the switches work in model years that are different from the car the switch came out of. I cannot verify that and haven’t tried it .
