Wipers Stopped Working After Radio Install
Adam taggart
20
I have a 92 fox vert 2.3, wipers worked fine in all modes before putting an aftermarket radio in, after that they don't even move or spray fluid. Are they related somehow? And of not where should I start to figure out what's wrong. They seemed to work perfectly fine before
.....checked the fuses they are all good
Did you do anything abnormal with regard to installing the radio? Or was it a standard install where you got the correct adapter harness and mounting kit and used butt connectors?
I don't see how you could have done anything to the wipers through a normal installation. I would suspect that the multi-function switch has failed. Is it possible that you would have disconnected the switch? Do the turn signals work?
Reactions: On392
