Wiring a cut off switch
  • Thread starter Thread starter DmnStr8
  • Start date Start date Dec 14, 2005
DmnStr8
NH
Dec 14, 2005
  • Dec 14, 2005
Hi Guys. I planned on making my rear mounted battery track legal so I just picked up a slightly used moroso cut off switch. I got the super duty one that has 4 terminals on the back. 2 1/2" ones and 2 3/16" ones.
The instructions say to wire the alt to one of the 3/16" terminals but says only to a max of 20amps. This seems rather low.
Can I just wire the switch as if it was a two pole switch like the other moroso switches? It seems like this would be the safer route since I believe that the 3G alt I am installing puts out more than 20amps at idle.
Here are the instructions: http://www.moroso.com/catalog/images/74102_inst.pdf
DmnStr8
NH
Dec 14, 2005
  • Dec 14, 2005
oops sorry double post. mods please delete
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 15, 2005
  • Dec 15, 2005
I have an answer, but it isn't simple.
You are right about the 3G alternator output: It is too much for the switch &
the 10 gauge wiring. Use the Moroso plan for the alternator wiring and you risk a fire.
There is a solution, but it will require about 40' of 18 gauge green wire.
Wire the battery to the two 1/4" posts as shown in the diagram.
The alternator requires a different approach. On the small alternator plug
there is a green wire. It is the sense lead that turns the regulator on when
the ignition switch is in the run postion. Cut the green wire and solder the 40'
of green wire between the two pieces. Use some heat shrink to cover the
splices. See http://fordfuelinjection.com/?p=7 for some excellent
help on soldering & using heat shrink tubing.
Run the green wire back to the Moroso switch and cut off the excess wire.
Try to run the green wire inside the car and protect it from getting cut or
chaffed. Crimp a 18 gauge ring terminal (red is 18 gauge color code for the crimp
on terminals) on each wire. Bolt one ring terminal to each of the 3/16" studs.
Do not add the jumper between the 1/4" stud and the 3/16" stud as shown it the
Moroso diagram.
How it works:
The green wire is the ignition on sense feed to the regulator. It suppiles power
to the regulator when the ignition switch is in the run position. Turn the
Moroso switch to off, and the sense voltage goes away, the voltage
regulator shuts off and the alternator quits making power.
See the following website for some help from Tmoss (diagram designer) &
Stang&2Birds (website host) for help on 87-90 wiring
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
Diagram courtesy of Tmoss and Stang&2birds.
Some more tips for a rear mounted battery...
Rear mounted battery ground wiring. Follow this plan and you will have
zero ground problems.
One 1 gauge or 1/0 gauge wire from battery negative post to a clean shiny
spot on the chassis near the battery. Use a 5/16” bolt and bolt it down to
make the rear ground. Use a 1 gauge or 1/0 gauge wire from the rear ground
bolt to a clean shiny spot on the block.
One 4 gauge wire from the block where you connected the battery ground
wire to the chassis ground where the battery was mounted up front. Use a
5/16” bolt and bolt down the 4 gauge engine to chassis ground, make sure
that it the metal around the bolt is clean & shiny. This is the alternator power
ground.
Crimp or even better, solder the lugs on the all the wire. The local auto
stereo shop will have them if the auto parts store doesn't. Use some heat
shrink tubing to cover the lugs and make things look nice.
The computer has a dedicated power ground wire with a cylindrical quick
connect (about 2 ½”long by 1” diameter. It comes out of the wiring harness
near the ignition coil & starter solenoid (or relay). Be sure to bolt it to the
chassis ground in the same place as you bolted the alternator power ground.
This is an absolute don’t overlook it item for EFI cars
DmnStr8
NH
Dec 15, 2005
  • Dec 15, 2005
That seems a lot more complicated than the wiring I have seen for a 2 terminal switch. Should I just drop this switch and get a lower rated one 74101?
Or was this another way to wire alt to the switch without having to run the alt power wire to the switch? The switch should be able to handle it. Its is the 300amp continous 1000 amp switch.
Sorry tad confused. Your method is like none I have seen for a battery relocation. I'd perfer to just do it the way everyone else has done it.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 15, 2005
  • Dec 15, 2005
Suit yourself. If you understand electricty and look at the diagram, it makes perfect sense. If you don't understand electricity, nothing I can say will change your mind.
Cut off the regulator sense power and the alternator quits making power. No spikes, no surges, it works just like turning the ignition switch off. The design mimics the stock factory method of shutting off the alternator.
Most of the other methods I have seen disconnect the alternator from the battery. The resulting voltage spike can damage the alternator, computer and other electronic gear.
In case you have any doubts about my electrical backgound, it spans 42 years of automotive electrical experience. Included in that 42 year span is 11 years as an aircraft mechanic and a 2 year degree in electronics and 26 years of fixing computers.
DmnStr8
NH
Dec 15, 2005
  • Dec 15, 2005
I have non doubts about your ability. In fact after I posted I realised your method would probably be softer on the car's system. Sorry if it sounded like I was questioning you I just wanted to know if I could do it the other way as well.
Thanks for your help. I really did appreciate it.
HISSIN50
34
129
Dec 15, 2005
  • Dec 15, 2005
One would be hard-pressed to do better than what JR recommends in anything he posts about (he is at the top of the SN wisemen).
His amazing understanding of underlying systems allows him to make excellent recommendations. I personally would not stray far from any suggestions he offers. Good luck with your project.
DmnStr8
NH
Dec 15, 2005
  • Dec 15, 2005
I think I was hesitant because I have been researching the other method for awhile now and was comfortable with what it intailed for my setup. I fixing the previous owners halfassed battery relocation.
I assume if I go by your suggestions JR that I would wire the new 3g alt I am installing as if the battery were still in the front?
I had been using boffhomers diagram and suggestions to plan out my little project.
Thanks for all the help.
rd
3,316
63
109
Ocean Springs MS
Dec 16, 2005
  • Dec 16, 2005
I am researching this issue at the moment.
I asked the Flaming River tech line, and the guy said to just hook the disconnect switch up to the pos wire. He said that for emergeny use only, it won't be a problem. That did not sound quite right....
I had originally planned to figure out the setup described above, but I'm lazy, and all the other directions just say "alt wire" but not which one. So I have not gotten to this project yet.
So the plan is to have the field exciter wire or "field control wire" switched off when the power switch is turned off? (hope thats the right term, I'm a civil engineer, so it's all just blue sparks to me)
I'm dealing with 1982 alternators with separate reguators, here.
So far this is far and away the best explanation I have ever seen on this.
Any more insight would be appreciated.
rd
3,316
63
109
Ocean Springs MS
Dec 16, 2005
#10
  • Dec 16, 2005
  • #10
I guess it is the voltage sensing wire that you switch, not the actual field control wire?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 16, 2005
#11
  • Dec 16, 2005
  • #11
You are right. It is the one designed to be turned off & on to control the alternator. An 82 model may have a different color wire for the alternator, but the idea is the same.
AutoZone wiring diagrams for Mustangs
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
Yes.
Here's websites with pictures of the 3G installation...
See http://www.geocities.com/smithmonte/Auto/3G_130A_Alternator_Upgrade.htm - all the tech data you could ever want to know
OR
http://www.mustangcentral.net/tech/alternator.html - excellent pictures of installation
Use these sites for information on the right way to do the wiring. Some people will tell you that you can skip the wiring upgrade, but it will catch up with you sooner or later. A fire in the wiring harness is ugly and expensive.
Under no circumstances connect the two 10 gauge black/white wires to the 3G alternator. You will have fused the circuit to pass 190-215 amps (125-150 amps depending on fuse size for the 4 gauge main and 65 amps for the two 10 gauge wires). The resultant overcurrent capacity can make a nasty fire if the alternator develops a full internal short to ground.
Electric fan = 3G alternator if you want long life & reliability from your car.
The electric fan saves some HP. The stock fan's parasitic drag runs from 7-12 HP depending on who you talk to. The electric fan uses about 1/2 HP of power from the electrical system.
Figure this:
Ignition system & computer = 12 amps
Fuel pump = 12 amps
Exterior lights = 15 amps
Fan (heater or A/C) = 15 amps (can run between 5-25 amps depending on setting)
Radio & instruments = 10 amps
Wipers = 10 amps
That's grand total of 74 amps from a 65 amp alternator. Talk about overdrawn at the bank!
Prefab 4 gauge wiring with lugs already attached can be found in the electrical parts area of most auto parts stores. Use some string to lay out the cable routing and determine the length.
To do your own custom cable setup, here are the parts:
See WWW.partsexpress.com for the fuse & fuse holder.
Fuse @ $3.90 each (need one) http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=071-952
Fuseholder @ $5.80 each (need one) http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=263-630
4 gauge black wire @ $1.25 a foot (use string to lay out routing & determine length) http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=100-196
4 gauge red wire @ $1.25 a foot (use string to lay out routing & determine length) http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=100-194
4 gauge ring crimp terminals (package of 5) $3.25. http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=095-584
Don’t forget the alternator power ground!!!
The secondary power ground is between the back of the intake manifold and the driver's side firewall. It is often missing or loose. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges. Any car that has a 3G alternator needs a 4 gauge ground wire running from the block to the chassis ground where the battery pigtail ground connects.
M
67 Mustang Ignition Switch Wiring Diagram needed
  • Michaelell
  • Sep 14, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 3, 2026
Michaelell
M
R
Electrical Trunk Mount Battery and Cut Off Switch- Need Help
  • Rcdgl
  • Nov 20, 2024
Fox 5.0 Mustang Tech Nov 20, 2024
nickyb
  • dan50
  • Jul 18, 2026
dan50
F
Electrical From scratch: alternator wiring
  • fox racer v2
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 23, 2025
fox racer v2
F
Forced Induction Total Timing under boost
  • Dontknowchit
  • Aug 27, 2025
Fox 5.0 Mustang Tech Aug 28, 2025
Dontknowchit
