Wiring an aftermarket tach
  • Thread starter Thread starter 92 GT Florida
  • Start date Start date Jun 2, 2010
9
92 GT Florida
9
Florida
Jun 2, 2010
  • Jun 2, 2010
I have converted a 93 lx into a GT and am trying to wire a aftermarket tach. The problem is that when I hook it to my coil it is not registering. I do have a msd coil ignition but no MSD 6al box. Any clues?
Grn92LX
Fidanza Man!
6,819
64
129
New York
Jun 2, 2010
  • Jun 2, 2010
you sure its wired to the negative side?
gearheadboy
1,425
177
84
Greencastle Pa
Jun 2, 2010
  • Jun 2, 2010
Thats my guess..green wire (autometer) to the side of the coil closest the drivers fender on my car.
9
92 GT Florida
9
Florida
Jun 2, 2010
  • Jun 2, 2010
Installing an aftermarket tach with a msd coil
Yes, I have every wire hooked up correctly but the negative side on my MSD blaster coil is hot (giving voltage thru it). I have a HEI distributor and MSD blaster coil. Will I need the HEI wiring harness as I have tried splicing every wire on my distributor and the negative side of my coil. I am lost can anyone help?
Thanks
Dave
HISSIN50
34
129
Jun 3, 2010
  • Jun 3, 2010
Do you have an aftermarket box too? If so, you'd likely use the tach port.
I'd recommend that you remove your phone number from this public forum. Then I'd recommend calling MSD and ask them what they suggest.
Good luck.
9
92 GT Florida
9
Florida
Jun 4, 2010
  • Jun 4, 2010
I do not have a box. I only have a MSD blaster ignition coil. I have tried hooking it up to the coil and every wire on my MSD distributor and nothing. Does anyone think that it could be the tach that is messed up as they are sending me another. Please let me know how your is hooked up? This is a cheap JDM tach with shift light.
Codye3m
28
  • Jun 4, 2010
its from ebay right
9
92 GT Florida
9
Florida
Jun 4, 2010
  • Jun 4, 2010
Tach Installation
Yes , I wrote the company and asked if there was something wrong with the tach or how to check it but they didn't answer. He did however write me back saying he was sending a new one and I will send the old back so he can tell. Does it sound like I did something wrong, or the tach is ****?
HISSIN50
34
129
Jun 4, 2010
  • Jun 4, 2010
HEI dizzies have a dedicated tach wire, don't they? If it's a negative output and you're connected to it, and the tach is wired properly, you should be ok.
Do you have another car you can test the tach with?
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
D
Speedo and tach dead
  • Davinrobinson1
  • Jul 19, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jul 26, 2026
fasterthangas
F
M
Electrical Wiring issue
  • Maxnie21
  • Mar 23, 2025
Fox 5.0 Mustang Tech Mar 27, 2025
Maxnie21
M
