wiring gurus help please
  • Thread starter Thread starter wazazzle
  • Start date Start date Aug 20, 2005
W
wazazzle
618
In the dumpster behind McDonalds. WA
Aug 20, 2005
  • Aug 20, 2005
swapped my 89 butchered harness for this clean 90 harness. what in the world is this though. in the pic you see attached to the clutch pedal is a computer/connection. i rewired the top connector of it to match the old 89, but the second connector for that box doesn't exist. on the 89 connector there is four wires, but on the 90 connector there is 3 wires and it is looped back to itself. does this mean i dont have to connect it? should i just leave it with the loop back or will this hurt my car? i have searched wiring diagrams, links, and other treads but they don't show or explain what it is. any input would be appreciated, thanks
W
wazazzle
618
Aug 20, 2005
  • Aug 20, 2005
here another pic
D
Daggar
3,902
  • Aug 20, 2005
What color are the wires on the mysterious looped back connector?
W
wazazzle
618
Aug 21, 2005
  • Aug 21, 2005
im pretty sure its the clutch position switch... and since theres a loop that would mean the '90 harness was an auto. does anyone know if i can just leave this looped??? cause im don't know what wires to plug in if i had to rewire. i also heard that i can actually by pass the whole clutch in start. is this true??
W
wazazzle
618
Aug 21, 2005
  • Aug 21, 2005
thanks for all the input guys...LOL ..... well at least one....i believe the loop is actually fords simple solution to using a manual tranny cars harness and converting it to auto. the loop basically bypasses, so i can actually start the car in gear... whoopsy atleast no more need to clutch in to start.
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
F
Electrical From scratch: alternator wiring
  • fox racer v2
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 23, 2025
fox racer v2
F
Rally-Pac Wiring
  • Sparksteam
  • Oct 14, 2025
1965 - 1973 Classic Mustangs -General/Talk- Oct 15, 2025
Sparksteam
A
Electrical New O2 sensor harness has no jumpers (91/93)…
  • afjLX
  • Dec 11, 2024
Fox 5.0 Mustang Tech Dec 13, 2024
afjLX
A
Resolved Ignition switch questionable
  • Dontknowchit
  • Mar 14, 2025
Fox 5.0 Mustang Tech Jun 18, 2025
General karthief
