Wiring Help - Starter & Neutral Safety Switch
Ok so tonight I finished up my wiring for the car. I was trying to test it out by turning the key over to engage the starter.
When i turned the key nothing happened. So my dad mentioned something about the Neutral Safety Switch, which i didnt think i had wired up. So we decided to just try to ground them out or w/e. We stick a bolt into the gray connector with 4 prongs.
I turned the key and the starter kicked over and started trying to crank the motor up, i turned the key off and took it out of the ignition and the starter kept cranking.
This is my problem, i don't know why it did that. I took some pictures of the plugs, and i also wanted to know what the plug is that plugs right next to the speedo cable?
Thanks for the help!
-AJ
That plug you pictured looks like part of the O2 sensor harness to me. I haven't checked out the transmission plugs in a while though, so it could be similar. The plug by the speedo cable is for the vehicle speed sensor (VSS). I haven't had a Fox in around 8 1/2 years now, so I'm not absolutely certain anything plugs into it. On my 95 it has that, but mine's an electronically operated speedometer, so it has to.
was the car originally an automatic? that first connector is the same that was on my original aod, 2 wires go to the nss (jumped with a stick), the other two for reverse lights.
the second thing next to the speedo cable i think is called the vss, not exactly sure what it does, but obviously something to do with speed detection.
not sure on the still cranking thing, maybe something funky with the ignition switch itself?
Going by the pics the car looks like an auto. The gray plug would go the the Neutral Start Swtich (switch is closed when gear selector is in Park or Neutral) and the backup lamp switch.
The last pic is of the VSS (Vehicle Speed Sensor) and is used for cruise control.
Ok thanks guys, the car is still an automatic its a built C6. I dont have cruise control anymore, so I'm gonna remove the vss from the tranny. I got some ideas on a few things i'm gonna try to fix the problem about the starter. Ill let ya know if i get it figured out.
-AJ
