wiring in a eec
dadslx
59
hello im sure this horse was beat to death but i am really beating myself up here. 1969 cougar doing a 351 efi conversion..using my stock short block 351 efi lower 302 upper from a 89 mustang along with ecu anf complete harness. just wondering a few things...mainly wiring up power to the ecu..according to the reading i have done it is suggest you use the relay towards the ecu if im not mistaken to power the ecu and fuel pump. well just curious but i would assume the green connector is for the body harness to the old mustang which will of course not be used. ford used this connector to power the ecu can i power the ecu by splicing the required power wires onto my solniod from this connector? i know its not this easy but really the way i see it the harness will plug into required sensors then i wire in the fuel pump and power the eec/ecu to achieve required power to harness and sensors. power up the ignition system and boom running efi..lol..or am i missing the big picture?
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
AutoZone wiring diagrams
For 79-88 model Mustangs
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c1528004e28c
For 89-93 model Mustangs
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c15280069677
For 94-98 model Mustangs
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c152801f5e3b
For 1999-2005 model Mustangs
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c152801ef7d7
