  • 1994 - 1995 Specific Tech
Wiring problem
  • Thread starter Thread starter drewzx3
  • Start date Start date Jul 22, 2005
D
drewzx3
411
Louisiana
Jul 22, 2005
  • Jul 22, 2005
My car keeps blowing the fuse for the power driver side seat and cigarette lighters. It happens as soon as you put the fuse in most of the time and sometimes it will not blow for about 10 minutes and then it will. Does anyone have a wiring diagram so I can try to find the problem? Any suggestions?
mytight95
2,605
Dothan,Al
Jul 23, 2005
  • Jul 23, 2005
i do.....give me till later to post it....
Btw for what it's worth, sounds like you have a bad motor or something.....
jason
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Jul 23, 2005
  • Jul 23, 2005
Did you check the haynes manual? Just curious if it has anything decent.
Scott
D
drewzx3
411
Louisiana
Jul 24, 2005
  • Jul 24, 2005
jason
A bad motor in the power seat?
HISSIN50
34
129
Jul 24, 2005
  • Jul 24, 2005
Make sure there is no change stuck in the cig lighter bottom. And I might stick a head under and check the wires under the seat to ensure there is not a short to ground.
If no go, I would unplug everything on that circuit (Cig lighter, etc) and plug them back in (one at a time) till the fuse blows when you reconnect a circuit. That is the bad circuit. Troubleshoot from there.
Good luck.
mytight95
2,605
Dothan,Al
Jul 24, 2005
  • Jul 24, 2005
you can zoom in on it and get the idea..... for some reason that is the best my scanner would pick up the diagram.............
jason
R
rockin_rick
968
Jul 25, 2005
  • Jul 25, 2005
IIRC, there was a recall about the power seat harness on the drivers (both?) sides. The harness was tied to the seat frame, and they discovered that it could cut into the wires and short out. The remedy was to simply cut the harness free. Perahps you are shorting out your seat harness....
Rick
D
drewzx3
411
Louisiana
Jul 26, 2005
  • Jul 26, 2005
I pulled out the console and got a handfull of change out of it and since then it hasnt blew the fuse yet. Hopefully that is what it was. thanks everyone
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
T
2002 V6 3.8L Help Me
  • TheIncompetentMechanic
  • Apr 4, 2026
  • 2 3
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
T
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Electrical Fuse 8, Light Green / Black Wire
  • bleedinggreen
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 26, 2025
bleedinggreen
