wiring problem
  • Thread starter Thread starter 68_stanger
  • Start date Start date Aug 17, 2007
68_stanger
131
Petoskey, MI
Aug 17, 2007
  • Aug 17, 2007
ok, I have a 68 coupe with a 302 auto. I am still having a hard start problem hot and cold, but pretty much have it tracked down to low voltage going to the coil, when I first turn the key on, I get +/- 6volts to the positive side of the coil, obviously not enough, when the car finally starts gets a good 13 or so going to it. now shut the car off, turn the key back on a good 12 and it'll fire right back up. let it sit for a while, it'll only have +/- 6 volts and requires a bit of cranking before she starts.
Now the question is the "crank" wire apparently has a problem, any reason I can't just run a new one right from the key switch so I know I have a good 12V at the coil whenver the key is on?
btw I am running the pertronix ignition module in place of the points.
mustangmike6996
5 Year Member
Nov 10, 2005
483
clinton twp, MI
Aug 18, 2007
  • Aug 18, 2007
whats the battery voltage???? if the voltage matches the voltage at the coil then you may have a current draw when the vehicle is shut off
T
TOM B
20+ Year Stangneter
Nov 15, 2002
872
Harrisburg Pa
Aug 19, 2007
  • Aug 19, 2007
YOU MUST run a new 12 volt wire from your ignition switch (ON) to the
Pertrinix red wire for it to work properly. Early mustangs have a resistance wire in the dash wiring to bring the voltage down to about 7 volts, this is for POINTS ignition only. If you update your distibutor to a aftermarket electronc distributor like Pertronix, MSD, you must have 12 volts.
Again this 12 volt sourse MUST be switched, do not run a hot wire that is not switched and do not let the key on without the engine running if you have a Pertronix ignition or it will burn it out.
Did I fry something messing with my ignition?
  • 85gtCOBRA
  • Oct 18, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 15, 2025
85gtCOBRA
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
  • brandyn200
  • Jun 20, 2026
AeroCoupe
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
