Wiring Probs
Phatt_daddy
219
Hytop, AL
Recently the speedometer in my 95 GT Vert stopped as well as the interior lights and dash clock. thinking that the top was leaking and causing the #4 and #8 fuses to blow as soon as they made contact, I pulled the dash and went through the entire dash harness checking every wire and then rewrapping before re-installing. NOT THE PROBLEM...... as soon as I reconnected the grey plug on the drivers side kick panel, both fuses blew immediately. Does anyone know exactly what all those two fuses go for? Car still runs and drives I just have no speedo. Ive tried searching but cannot find anything that helps me out.
Thanks,
Nate
Diagrams courtesy of Tmoss & Stang&2birds
Click on the picture to enlarge it....
94 & 95 Mustang 1994-1995 Engine Fuses Door Controls schematic, in color, by TMoss:
94 & 95 Mustang 5.0 1994-1995 Fuse Box schematic, by TMoss:
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Wiring & Engine Info Everyone should bookmark this site.
94-95 Mustang wiring diagrams
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Ignition switch wiring
O2 sensor wiring harness
http://www.veryuseful.com/mustang/tech/engine/images/mustangO2Harness.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pin out
Fuse box layout
Mustang 5.0 Lights and Radio schematic, by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/mustangFoxLights-Radio_diag.gif
87-92 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang87-92 PowerWindowWiring.gif
93 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang93PowerWindows.gif
T5 Cutaway showing T5 internal parts
http://www.veryuseful.com/mustang/tech/engine/images/5_Speed_Cutaway_Illustrated.jpg
Visual comparison of the Ford Fuel Injectors, picture by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/Ford_Injector_Guide.jpg
Convertible top motor wiring http://www.veryuseful.com/mustang/t...ch/engine/images/mustang88VertTopMotorCkt.gif
