Wiring Questions
Hey guys, been a while since I have been on here, Life, kids, work and a slew of other things have kept me away from here. But I'll get to the point.
I am in the process if a GM LS swap in my car. I know there are those on here that don't agree with that, but it's my car, and I can always put it back.
I removed the entire engine harness when I sold my 302/t5 combo. I am am in the process of slimming down the dash harness and getting rod of the stuff that isn't needed (cruise, Airbag stuff, door chime). What I need to know is where do i find the wires for the following, and in what connector are they in.
Fuel pump power
Check engine light
Tach
Oil pressure
Water Temp
A/C (high pressure switch, and the clutch)
Charge light
My goal is to have as much of the factory gauges work (94-95 GT cluster, 93 GT body/dash harness, and a 2002 GM truck engine harness) as I can. I have the Dakpota digital SIG-5 speedo corrector to take my 4k pulse per mile VSS signal and translate it to my 8k PPM Speedo. Tach signal from the GM ECM is a 4cyl signal, and I can change that in the tune. For my Oil and water I am going to use ford senders in the respective locations, but need the wire locations to make it all work.
Thanks for the help!
Charlie
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
