wiring up a msd
Im guessing you purchased all this used, since your asking for the instructions, because MSD supplies great directions with there ignitions..
Like mentioned, check out MSD's site.. Otherwise its fairly simple.. YOu have a ground, power, and two wires going to the coil, and two going to the coil conector. I believe it was orange/black for the coil, respectivly, positive/negitive.
And i think it was white/red or somthing for the coil conector. Real simple stuff..
You have the window switch and BTM thrown in there, so im sure this effects how your 6AL is hooked up..
Just check there site, if nothing is found, come back here, and do a few searches for "MSD diagram" or "MSD hookup" or "MSD" or such..
Its also a good idea to buy the wireing harness adapt. as it has a end that will plug into the factory coil and coil plug that has matched ends on it to plug into the MSD boxes. Makes for a easy install, with no splicing/cutting of wires, and easy uninstall in case you ever have a failure.
