wmburns or anyone else, Need some more advice.
1987stangman
684
23
Well, a couple weeks or so ago I posted up a miss fire issue on my 96' GT. I thought I had the issue worked out but didn't.
The mechanics of the problem is that I have a P0175 code (rich bank 2). I can hook up live link and look at all 8 cyl's and see that every single cyl on bank 2 has random misfires. At this point, I have tested and replaced every single thing I can think of. 2 new coil packs, new wires. FP is good I have done a compression test on all cyls which is good. I even replaced the EGR valve.
I tried switching the front O2's to see if maybe there was a bad one on bank 2 but the situation is the same. I'm totally lost with this one. I also had extra CKP CSP sensors that I tried.
Is there any at all possibility that I could be dealing with some sort of cam timing issue?
Like I said before in my other posts. The motor is a 04' PI engine that had around 69K on it when installed and ran perfect until about 2 weeks ago.
I'm pretty new to the whole live link data logging stuff. I would be nice to know what PIDS to use that would point me into the right direction of the issue.
  • Sponsors(?)
wmburns
SN Certified Technician
Aug 14, 2009
5,825
501
194
Houston Texas
Let talk this out. I have help 3 ppl so far where there motor had one side 180 degrees out of time. The usual symptom is it idles ok but does not make good power. In two cases, raw fuel came out of one side. In another case, a temperture reading of the exhaust manifold showed a huge difference in temperature between the sides.
If the motor was out of time, why would it work fine for a while and then not? To me, it seems more like something changed.
That something could be the timing chain adjusters on the right side. However, the reported mileage on your motor is a little low for that sort of thing.
Any noise from the timing chains?
However, based upon my personal experience, if this were my car, I would get an oil filter cutter and inspect the oil filter element for bits of metal.
After already having problems with one fuel injector, consider having them all cleaned and flow tested. I have had great luck with injectorrx.com. Once cleaned and tested, they are as good as new. Cheaper than new.
I could see a case where a single stuck open injector could cause this. Remember, the PCM can only control the fuel trim values for an entire bank. If one injector is dumping fuel, then the PCM resonds by leaning the entire bank.
What do the spark plugs look like? Any carbon fouling or signs of running rich?
Any exhaust leaks?
What about vacuum leaks? Focus especially hard on the right side of the motor. PCV valve, PCV line, PCV grommet, oil cap, valve cover gaskets.
What are the long term fuel trim (LTFT) bank 1 and 2 values doing at idle and under load?
1987stangman
684
23
Any exhaust leaks?
Some chain noise at start up when it has not been started in a day or so. When I had the engine on the stand and had the front cover off I inspected the guides and they looked good. Hard to say about the adjusters as they were not pumped.
I looked and looked for vac leaks. I'm going to try and smoke it and make sure tho.
As far as LTFT values. bank 2 is always higher in value. I will data log it again tonight and see what they are for certain.
I never messed with the chains or guides when I had the cover off and the only reason I had it off in the first place was because I had to swap my NPI cover over to it to use my coil packs.
No exh. leaks.
EDIT: What's the chance of having a bad computer? I feel like a total newb here. This may be my first mod motor Mustang, but certainly not my first and certainly not my first trip down repair lane on a car or truck. It's frustrating as hell. I can usually systematicly figure issues like this out with ease.
Thread starter Similar threads Forum Replies Date
GDawg High Idle - anyone...? WMBurns?? SN95 4.6L Mustang Tech 31
I 2001 Cobra PATS 1:6 issue. HELP WMBURNS SN95 4.6L Mustang Tech 1
D Wmburns Help W/pats 2000 Ford Mustang Gt SN95 4.6L Mustang Tech 1
R I Need Your Help With A Pcm Problem, Wmburns? SN95 V6 Mustang Tech 9
paintballpyro1 Engine swapped motor, having starting issues(wmburns?) SN95 4.6L Mustang Tech 10
Night Shifter wiring help...wmburns and all other knowledgable SN95 4.6L Mustang Tech 5
B Anyone done the 351W swap? I need some info. 1996 - 2004 SN95 Mustang -General/Talk- 1
C Power estimates anyone? 1994 - 1995 Specific Tech 3
D Can anyone adjust my tune for 42lb injectors? SCT X4 tuner Digital Self-tuning Forum 1
P AOD problem anyone with experience? Fox 5.0 Mustang Tech 28
Andresquintana.mma Fox Anyone know what heads these are 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 25
Andresquintana.mma Fuel Anyone know what fuel injectors these are? Fox 5.0 Mustang Tech 5
Itstiller WTB/Trade Anyone selling Bassani X pipe? Exhaust Parts 0
C Anyone else like to drive twisty roads? 2005 - 2014 S-197 Mustang -General/Talk- 6
A Can anyone tell me whats up with this exhaust sound? Mustang Sound & Shine All 0
silverlx50 Engine Does anyone have a picture of the O2 sensor harness orange ground wire? Fox 5.0 Mustang Tech 5
Grn92LX Digital Tuning Anyone know the distance between the injector and valve seat? Fox 5.0 Mustang Tech 0
2000xp8 Anyone fit 2 child seats in the back? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 30
L Engine Anyone know where this belongs to? Fox 5.0 Mustang Tech 1
J Progress Thread ANYONE INSTALLED A 1997 COBRA REAR END ASSEMBLY IN 65 COUPE? 1965 - 1973 Classic Mustangs -General/Talk- 3
M Brakes Does anyone know specific casting numbers on 1989 GT O.E. Calipers? Fox 5.0 Mustang Tech 11
P Fox Has anyone ever used sn95 emission valve solenoids in a foxbody. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
96pushrod Anyone else have a copilot 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 40
1320stang I'm back after a long hiatus.... Not sure if there is anyone still around that even remembers me.... 1965 - 1973 Classic Mustangs -General/Talk- 9
H Anyone have any info on putting a 86 svo doghouse on a 93 convertible? The Welcome Wagon 0
H Anyone ever heard of putting an entire SVO front doghouse on a 93 convertible? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 56
derek2079 Can anyone tell me what noise this is coming from my engine bay? VIDEO INSIDE 1965 - 1973 Classic Mustangs -General/Talk- 7
J Does anyone know where this wire goes? Other Auto Tech 28
kiddiccarus Does anyone customize the interior of the 94-95? I am running into brick walls 1996 - 2004 SN95 Mustang -General/Talk- 0
Red50Fox Anyone familiar with SSTUBES.com? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
90limited Anyone know if MAC is still shipping parts 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 36
BMan5150 Anyone have the optional Ford Safety Package? 2015+ (S550) Mustang -General/Talk 0
R Can anyone ID these old Ford disc brakes? 1965 - 1973 Classic Mustangs -General/Talk- 5
S Setting Up a Paint Booth in Your Garage - Anyone Tried These The Welcome Wagon 0
M Drivetrain Vibration In Every Gear T-5 Tremec! Fox 5.0 Mustang Tech 4
J can anyone measure foxbody and notchback rear window size? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 17
jenrik Anyone still use this? SN95 4.6L Mustang Tech 9
revhead347 Has anyone ever sent in an instrument cluster for repair? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
Mstng93SSP Has anyone used the tool to hold lifters up for cam change? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 28
Reddevil91 93 cobra w whaaaaat? Anyone else seen this build! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 77
D Anyone have part number for 10th anniv carbon pattern shift knob? SVT Tech Forum 0
ndfox92 Fox does anyone have a victor efi intake for a 351w they want to part with? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
G Suspension Can anyone ID my spindle year? Fox 5.0 Mustang Tech 3
J Electrical can anyone help ID these Fox 5.0 Mustang Tech 0
G Has anyone used this header on their I-6 ? 1965 - 1973 Classic Mustangs -General/Talk- 0
silverlx50 Wheels-Tires Anyone running 315/30/18 tires? Fox 5.0 Mustang Tech 3
M Does anyone know what the hole to the left of the oil pressure sender is for?? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
S Anyone swap a 347 stroker in a 94-95? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 16
B Was rear-ended, anyone have market value comps? What is it Worth?!?!? 2
