  • 1994 - 1995 Specific Tech
Won't Start Need Help!!
  • Thread starter Thread starter TDsn95
  • Start date Start date Mar 23, 2014
TDsn95
25
Clarkson, Kentucky
Mar 23, 2014
  • Mar 23, 2014
I have a 1995 mustang I swapped from v6 auto to carb 302 with a aod. My problem is when i turn the key over to start it nothing happens my starter is good and the battery is charged i have lights and radio with the key on but thats all what could be the problem? the car did start when it was still a v6.
madspeed
Colonel Mustard
1,332
204
a van down by the river
Mar 23, 2014
  • Mar 23, 2014
Is this a new problem since the swap?
TDsn95
25
Clarkson, Kentucky
Mar 23, 2014
  • Mar 23, 2014
Yes it is
TDsn95
25
Clarkson, Kentucky
Mar 23, 2014
  • Mar 23, 2014
The aod doesn't have the range sensor like the aode but I put in a 5 speed transmission harness I thought would by pass it. Is that right or do I have to do something else?
toyman
1,944
54
79
Vernon BC
Mar 24, 2014
  • Mar 24, 2014
What ECU are you using? If it's the one from the V6 you may need to change to a T4MO.
TDsn95
25
Clarkson, Kentucky
Mar 24, 2014
  • Mar 24, 2014
Okay I'll get one today and post back this afternoon.
TDsn95
25
Clarkson, Kentucky
Mar 24, 2014
  • Mar 24, 2014
Okay so i got the new ecu put it in and I have the same problem except the ecu is clicking now when i turn the key on any ideas on that?
toyman
1,944
54
79
Vernon BC
Mar 24, 2014
  • Mar 24, 2014
Clicking? Are we talking about the same part? There is nothing to click in the ECU but the CCRM houses 4 relays one of which is for power to he ECU. For better clarification are you saying the engine doesn't crank or cranks but doesn't start? If it's the former check the power cable to the starter and the battery to engine ground.
TDsn95
25
Clarkson, Kentucky
Mar 25, 2014
  • Mar 25, 2014
Yes the starter isnt cranking or making a click like a low or dead battery checked all cables and they are good so im kinda lost as what it could be.
TDsn95
25
Clarkson, Kentucky
Mar 25, 2014
#10
  • Mar 25, 2014
  • #10
Okay so its the CCRM clicking sorry for the confusion any ideas on why it is clicking when i turn the key on
toyman
1,944
54
79
Vernon BC
Mar 25, 2014
#11
  • Mar 25, 2014
  • #11
Sounds as if the battery is nearly dead. A voltage reading here isn't all that important. Pull the battery and have it load tested. I'll bet it fails.
TDsn95
25
Clarkson, Kentucky
Mar 26, 2014
#12
  • Mar 26, 2014
  • #12
Thanks for all your help I really appreciate it! The battery is the one i got with the car so it probably is junk I'll get it tested today and I'm sure get a new one. I'll slap the new one in today and see what happens.
TDsn95
25
Clarkson, Kentucky
Mar 26, 2014
#13
  • Mar 26, 2014
  • #13
Well got the new battery in, same thing turn the key on CCRM clicks twice and starter does nothing.
TDsn95
25
Clarkson, Kentucky
Mar 26, 2014
#14
  • Mar 26, 2014
  • #14
Problem is fixed! It was the dead battery and I was double checking all the grounds and the ground for the left head light was cut. Spliced it back together and the car turns over fine now. Gonna pour some gas in it and fire it up for the first time since the swap tomorrow. Thank you toyman for all your help!
toyman
1,944
54
79
Vernon BC
Mar 26, 2014
#15
  • Mar 26, 2014
  • #15
There is no way a headlight ground being cut would prevent the starter from turning. The starter ampere draw would fry a 10 to 14 ga wire in seconds. If you haven't already remove and clean the battery to engine and engine to chassis ground terminals. These are 2 ga cables and are needed to carry a starter load of a few hundred amps. A dead battery I understand.
O
Resolved 2004 Mustang GT 4.6. No crank, no dash lights, No headlights or dome, No radio, no Hazards.
  • oldtimeracer
  • Aug 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 17, 2026
oldtimeracer
O
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
M
  • Mindseye007
  • Aug 16, 2026
Mindseye007
M
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
I
Innova scanner not working 88 5.0
  • Idkwhatimdoing
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 13, 2026
General karthief
