95 Gts electrical/starter issue i cant figure out.
So I'd just finished the build 2 years ago when the car was impounded..I jus got it back an when I put the key in an turn it to on the wipers cycle once an just a single click when I try to start it. New battery starter tested the altenator now starter/battery wires cleaned the grounds. Think it was 11.8 volts at the igniton when trying to start it. I'm aggravated an stumped here. Even with a push button bypassing the solenoid..nothing.
I use following guideline for Battery capacity after full charge:
12.9 Volt - 100% charge; 12.75 V - 75%; 12.5 V - 50% and 12.0 V - 25%.
Suggest you charge fully to 12.9 V and start to see if crank.
