  • 1994 - 1995 Specific Tech
wont start???
  • Thread starter Thread starter Lebedin8654
  • Start date Start date Nov 8, 2008
L
Lebedin8654
  • Nov 8, 2008
I have changed the ignition module.! it worked for about a week now when i go to crank it if the check engine light flashes it wont crank at all it will just turn over and over. but if i crank it with no check engine light it will fire right up! any ideas its a 94 gt
94GTCoupe
1,412
92
79
CA
Nov 8, 2008
  • Nov 8, 2008
try pulling the codes.
also,why did you install a new ICM?
94GTCoupe
1,412
92
79
CA
Nov 8, 2008
  • Nov 8, 2008
before the new ICM,would the car not start?
would it crank but not fire?
would the car shut off while driving?
would it start some day's ,and not some other's?
if so,it could be the PIP inside the dizzy.
1.you could replace the PIP,but you would need to press off the drive gear to disassemble the dizzy and replace it.
2.get a reman dizzy from the parts store.but,sometimes the PIP is not replace when the rebuild it.only the parts that are obviously bad.
(but,getting the codes would really help to narrow down problem.)
also, to :SNSign:
toyman
1,944
54
79
Vernon BC
Nov 8, 2008
  • Nov 8, 2008
I'm inclined to go with the stator (PIP) being the cause but my experience would indicate that that does not trigger a code. The OP post about the CEL would seemingly indicate that a fault code my be available.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Nov 8, 2008
  • Nov 8, 2008
Since you have a CEL, start by pulling codes. If it's a PIP failure, you should see code 211, and that would definitely cause a no-start condition.
L
Lebedin8654
  • Nov 8, 2008
once it cranks it runs fine and it has never just died! it just seems to crank when it wants to. i had the same problem so i got autozone to test the ICM and it failed so i replaced it the car cranked fine about 20 or 30 times now i get a flashing light and do cranking...i am gonna pull the code tomorrow i just have never done it before any tips?
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
All power lost at crank
  • saf_blu302
  • Mar 7, 2026
1994 - 1995 Specific Tech Mar 12, 2026
General karthief
9
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
O
Resolved 2004 Mustang GT 4.6. No crank, no dash lights, No headlights or dome, No radio, no Hazards.
  • oldtimeracer
  • Aug 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 17, 2026
oldtimeracer
O
