  • 1994 - 1995 Specific Tech
Worried!!!!
  • Thread starter Thread starter 95ConvGT
  • Start date Start date Sep 3, 2006
9
95ConvGT
65
Norfolk,Va
Sep 3, 2006
  • Sep 3, 2006
Well the fiance was driving the 95 home the other afternoon and as we were playing on a back road she said it started to sound like metal to metal rattling inside the engine compartment. Well i noticed a little bit of black smoke come out from under her car. most likely from the exhaust we don't run pipes on the Vert. well i am kinda scared to think of what it would be. I am hoping oil is not getting past the piston rings. Or she might have thrown a bearing somewhere. I have it set at 12deg time and we run 93 in it. Anyone have any ideas. I have not taken the car out yet as i am not wanting to even think of this.
9
95ConvGT
65
Norfolk,Va
Sep 3, 2006
  • Sep 3, 2006
well the rattling she was hearing is the heatshiled and only blew the pan gasket on the AODE. Thats the 2nd gasket in 6 months anyone know what to do to fix it????
fords2fast4u
1,426
Mission Viejo, CA
Sep 4, 2006
  • Sep 4, 2006
I posted something in responce to your original message as i missed your reply... my bad.
Bosko5.0
1,067
longwood, FL
Sep 4, 2006
  • Sep 4, 2006
are you using the for pan gasket that is reinforced or are you using a crappy cheap gasket there is a big difference. hopefully you get it fixed
P
Pennywise2
Banned
May 16, 2006
1,379
  • Sep 4, 2006
I am sorry to hear that man.
It could very we'll be detonation since you advanced
your timing to 12 degrees.You could try this put the
timing back to stock 10 degrees and drive the your car
easy and hard to see if it is detonation.Running 93 octane and advancing your timing to 12 degrees I don't
see why you would be having problems but,every engine
reacts different.Also make sure you are only useing good
name brand gasoline and not the cheap off-brand crap.
Good luck.
1994 Mustang GT 5.0 L Convertible
  • 94ns95
  • Jun 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 19, 2026
94ns95
9
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Lost my Foxbody
  • Mhalc1
  • Feb 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 17, 2026
Mhalc1
G
Electrical Getting good ground in 1991 Fox Vert for amps - getting popping noise when I turn on the lights?
  • gvanginkel403
  • Apr 11, 2026
Fox 5.0 Mustang Tech Jul 21, 2026
gvanginkel403
G
Progress Thread The Mach Returns - Update/build thread
  • squeak93
  • Feb 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Friday at 8:00 PM
squeak93
