WOT Detonation
  • Thread starter Thread starter iblue
  • Start date Start date Aug 18, 2005
iblue
29
  • Aug 18, 2005
I recently purchased a 1988 LX 5.0 and it is experiencing detonation @ WOT. The car is currently speed density (my mass air conversion parts are in the mail as I write this). The injectors on the car have been replaced recently (or so it appears) and I have only been running the car on 87 octane gas. When I purchased the car everything appeared to be stock with the original engine still in the car. The silencer was even still on the stock intake setup. Im going to be pulling the plugs tonight to check them out and I will probally run some combustion chamber cleaner through the engine since it has ~150K on it. What steps do you guys usually take when troubleshooting this kind of issue? Any help is appreciated, thanks.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Aug 18, 2005
  • Aug 18, 2005
Start by pulling the diagnostic codes, and checking the timing to see if it's over-advanced. Stock is 10 BTDC with the spout out.
iblue
29
  • Aug 18, 2005
I think a buddy of mine has a device for pulling the codes so I'll try that ASAP. Looks like I'll have to go buy a timing light tonight, no more being spoiled with coil pack setups.
HISSIN50
34
129
Aug 18, 2005
  • Aug 18, 2005
Michael is right. Another thing is to see if you can check FP while it is pinging.
Before assuming a pump, etc, dont forget to make sure the fuel filter is not old/clogged.
Good luck.
D
Daggar
3,902
  • Aug 18, 2005
A trip to a shop that has a good fuel injector cleaner (i.e. the IV bag that plugs into the fuel rails) might also be in order. It will clean deposits off of not only the injectors, but the piston tops, rings and anything else it comes in contact with.
iblue
29
  • Aug 18, 2005
Get this, plugged in the device my friend had that checks diagnostic codes and turned the key to then on position without starting the car and the code reader proceeded to get burned up from the inside and smoke started pouring out of it. This car REALLY has some personality. Tossed a bottle of Lucas Oil fuel system cleaner in it and checked the timing. The timing mark on the harmonic balancer was a few degrees from the bracket indicator towards the passenger side, set it bang on to the stock location and the misfiring was decreased. Set it another 4 or so degrees towards the drivers side and it stopped misfiring completely. When setting the timing I pulled the spout and set it back in when taking it for test drives. What has me confused is when the timing mark on the harmonic balancer is towards the drivers side of the bracket indicator isnt that advanced timing? I must have this confused, please tell me I do so I can stop scratching my head.
On a side note, car does run much smoother now and seems to idle at a lower RPM as well.
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
Looking forward to collaborating with my new community
  • phil2001svt
  • Sep 24, 2026
  • The Welcome Wagon
The Welcome Wagon Oct 10, 2026
phil2001svt
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
