wot tps voltage?
hey
ill make it short and sweet, unless im mistaken its a bad tps not everything new is good. If your old one is seeing the same voltage then you should be looking elsewhere for a problem, ecu and wiring including grounds.
hope i helped out
also make sure (as eluded to) that you have 5.0 volts (+-0.1) and a good consistent ground signal.
90lxnotch said:
its a new tps because everything for the drivetrain i bought new and the red wire for the tps is only getting 3.xx volts
Check the Orange/white wire for +5 volts +/- .25 volt. If it is OK, then replace the TPS.
No +5 volts on the Orange/white wire, look for bad connections.
Check the Orange/white wire at the EGR & MAP/BAP, no +5 volts, check pin 26 on the computer. No +5 volts there, computer is bad. If the +5 volts is OK on pin 26, then you get to chase through the wiring harness to find the bad wire/bad connection.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
no 5 volts out of computer its 3.00 volts and i have tried 3 computers what could it be
