would putting allitle hard block in my block be bad?
Filling the block does help keep the cylinder round and strengthen around the bores. Unless you go up the water pump holes it is a waste as far as adding strength, it also needs to be done before the block is machined, properly with a torque plate or head bolted in place to keep the block from twisting.
The block will still break straight up the middle since it is very weak in that area. Hardblok does more for a Chevy small block then a Ford based on the internal passages.
With a filled block in the 69-74 age range you will be fine around 500rwhp. Just add a girdle for piece of mind. As with the hardblock, make sure the main line is torqued and honed with the girdle on there.
mike.
IndyBlk5.0 said:
Well what can i do to strengthen the block to handle about 500rwhp ?
Thats going to be on a conservative tune by the way.
This is probably not what you want to hear, but with what you have for parts and what your goal is, I would not waste anytime with the factory block. Buy a FRPP wet sump racing block. It'll have the strength you are going to need to keep that motor in one piece.
You are going to spend a coupel hundred bucks on a girdle. Take that $300 and add about $1000 to it and go buy the M-6010-R302 block. You'll never break it. Think it's too expensive? Add up building your stock block and then add up building another for when you break it. It won't seem that expensive when you add up that cost.
How about 1600 for an R302 block, and then the price of machining it, another 500-600$...The lowest deal I've found so far is 2200 for a machined r-302 block to your door. Stock block have been known to hold 550 rwhp without a problem.....www.turbomustangs.com
I did a lot of research on hard blok and came really close to putting in my 351. If you use the brand "Hard Blok" they told me you can do it after the machine work had been done. But as people have already said it dosent really strengthen the block. Also to put it in you have to have the block bare and depending where you wan to fill it you might need to remove the freeze plugs. If i were you i would pass on it and use a girdle and make sure you get some good machine work done.
