Would this LCD Screen work ??
I was thinking about something similar, with a ps2 in the back seat, but I dont have the funds right now. You could try to make something yourself, but if you have never worked with fiberglass, you should probably go somewhere to get it installed the way you want it will cost ya, but you dont want to mess it up real bad, cause its right in plain sight no matter what...
A guy I know bought a 94 mustang with an LCD screen and PS2 installed into the dash. They took out the middle vents, dropped the CD player and air/heater controls down a slot, and had a custom mould made to accomodate a 5" by 4" or so LCD screen. They installed the PS2 where the passenger side airbag goes, moulded in nicely, keeping a factory look. I'm not sure how they ddid it, but it looks great. You just sacrifice your middle cents and passenger side airbag (is there one?).
Audio thread ..... really
Here's an install I'm thinking about for the Cobra.
Is that what you're looking at????
6.5" screen .... some cutting involved to fit.
cgrant said:
I was wondering if I could somehow mount this LCD screen in my center dash peice....any ideas?
http://7925.adahost.com/computer/index.html?loadfile=item13505.html
Seems like it sync's on NTSC (USA) or PAL (European) television standards. This means you have to have a TV tuner or computer that generates NTSC or PAL output (composite video). It doesn't say it will work with VGA, SVGA or XGA so the common personal computer video can't be directly used without a NTSC or PAL card stuffed in the box. It also says it uses 12 volt power. The chances are 12v automotive power is too dirty to use with a visual display so you'd likely also need a power filter or a DC-DC converter to power it. I'm not saying you can't do this, what I'm saying is the $119 price quote comes with some hidden costs. It would be real easy for your $119 project to cost $1,119.
Jeff
Jeff
all these techo geek talk is making me horny :rlaugh:
I do want to do something similer, but then I can't justify spending my ,omey on TV that only my GF gets its benefit, and when my car could a lot more go fast goodie... :shrug:
It's a Kenwood DDX-7015. It motors down, with a CD/DVD player behind it. Very, very cool piece. It is double din, and is a very basic install in a Mustang. Here is the info from the lit:
Got a car with a big dash opening? The DDX7015 is ready for it. This new in-dash touchscreen monitor/DVD receiver has a 2-DIN chassis, so you can get a factory fit and look in lots of different vehicles. The DDX7015 is packed with Future Ready/Already features and technology, including a 6.5"-wide, 16:9 touchscreen display, DVD-Video/CD/MP3/WMA playback, 24-bit digital-to-analog converters, and a brand-new GUI on-screen interface with touchscreen control. The fully-motorized 6.5"-wide LCD screen slides effortlessly down for disc loading, then returns to one of 6 user-selected angles for optimum viewing. The System E's+ Advanced Crossover System gives you all the adjustments you need to get the most out of whatever speaker's your system has, and System Q EX Sound Control makes it easy for you to fine-tune the sound until it's just the way you want it. There's built-in 50-watts x 4 amplification or you can use the high-voltage gold-plated front, rear and non-fading preouts with Kenwood Excelon power amps to create your dream system. (The DDX7015 even controls the A.M.S. functions of 2004 Kenwood Excelon power amps right from its touchscreen.)An A/V input/output expands your video source choices, and you can also add a Kenwood Excelon Music Keg and HD Radio or SIRIUS Satellite tuners. Connect the optional KDS-P901 DSP/Surround Sound Decoder to the DDX7105's digital output for a total 5.1-channel experience, complete with Dolby Digital and DTS surround sound decoding. A programmable security code brings peace-of-mind, and a full-function 10-key remote is included.
GENERAL FEATURES
- Clock
- Double-DIN Size In-Dash Mounting
- Finish: Silver/Ebony
- Iso-Mount Capability for Japanese Vehicles
- Programmable Security Code System
- Touchscreen Control with New Graphic User Interface
- Touch-Tone Buttons: Defeatable
AUDIO FEATURES
- A.M.S. Amplifier Control Interface: with Compatible Amplifier
- Attenuator with Smooth Volume Return: -20dB
- Audio/Video Inputs: 1
- Audio/Video Outputs: 1
- Digital Output
- Dolby Digital and DTS Digital Surround: Built-In
- DSP (Digital Signal Processing): when Used with Optional KDS-P901 Digital Processor
- DSP Vehicle Cabin Size Adjustment and Digital Time Alignment: when Used with Optional KDS-P901 Digital Processor
- Dual-Zone Control
- Electronic Audio Control (Volume, Balance, Fader)
- Front/Rear Fader
- High Voltage Preamp Output: when Used with Optional KDS-P901 Digital Processor
- Loudness Control
- Low Output Impedance (80 Ohms)
- Preouts: Front, Rear, Non-Fading (Gold-Plated)
- Source Tone Memory
- System E's + Advanced Crossover System
- System Q EX Sound Control: with User Memory
- Telephone Mute: 2-Way
- Tone Controls: Bass, Midrange, Treble
DISC PLAYER FEATURES
- Audible Fast-Forward/Fast-Reverse
- CD Text: 12 Characters
- Changer Control
- Digital Anti-Skip: 3 Seconds (DVD only)
- Digital Filter: 8-Times Oversampling
- Digital Optimum Servo Control
- Digital to Analog Converter: 24-Bit Resolution
- Intro Scan: Track
- Kenwood-Designed Superior Disc Transport
- Play/Pause
- Plays DVD-Video, DVD-R/RW, DVD+R/RW, VCD, CD, CD-R/RW and MP3/WMA-Encoded CD-R/RW Discs
- Precision Digital Timing (DPAC)
- Random, Repeat, Search: Track
TUNER FEATURES
- Automatic and Manual Tuning
- Automatic Memory Entry
- Direct Access Tuning
- HD Radio Ready
- High-Speed Multipath Control (CRSC) with ANRC
- Kenwood CR-2 Advanced Tuner
- Preset Seek Tuning
- Radio Data System (RDS)
- SIRIUS Satellite Ready
- Station Name Preset Play
- Station Naming: 24 Stations
- Station Presets: 24 (18 FM, 6 AM)
VIDEO FEATURES
- Adjustable Video Monitor Angle: 6-Step, Motorized
- LCD Screen: 6.5" Wide, 336,960 Pixels
- Motorized Slide-Down Screen
- RGB Input
- Selectable Screen Viewing Modes: Normal, Full, Just, and Zoom
- Video Input Automatic Signal Detection
- Video L-R Reverse Function for use with Rear-Facing Camera
- Widescreen (16:9) Aspect Ratio
Any body who is serious about one can PM me directly for a deal on one.
