Would you replace this upper to lower gasket
from6to8
There's suction so I used that end O_O
1,896
142
94
This gasket is not ripped or torn what are you guys think?
no I reuse mine many times.
If there was a leak the car will not idle correct? And the only thing that I saw was on the lower intake in the center you know where that hole is, I saw a little bit of the gasket material on it but on the gasket itself it doesn't look like anything really came off so I guess it just probably is a little bit up smudge of paper but it I mean it actually look like there's more on the intake and self on the lower than it is that came off of the gasket so I don't know why LOL.
Normally I reuse, but for me time=money so if I had any reason to suspect a possible risk of leakage I’d just toss it in the trash and get a new one.
9 times out of 10 I reuse
Okay yeah it's so easy to pull off in swap out you know I'm just going to reuse them if I have out of which was I will order a new set. No need and just throwing money in the trash for no reason
