My car is runinng very lean and need a quick temporary fix- I put the 19# tube back into my C&L 76MM and the car runs and idles perfectly fine- this would richen up the mixture slightly correct?
saleenx029 said:yes I mean Wideband 02 sensor. My freind bought one for less than 300 bucks and it make the dyno unneccessary, unless you want the numbers. Combined with a tweecer system and the datalogger, you can record runs and tune the whole rpm range yourself with a laptop onboard everywhere you go, and never need to go to the dyno or need someone else to tune the car.
Is the Tweecer RT the best wat to go or are there other options? Where do I get a wideband o2? I guess I need to go to an exhaust shop to have it installed. Does the Tweecer do boost retard or is it by RPM? Thx.
