wtf happened?! sort of urgent! PLEASE LOOK
You can buy a noid light (they are about 5 bucks at most parts stores). It is like a little LED test light. It will flash every time the injector is commanded to squirt.
I suppose you could use an LED test light (if you own one already).
I'd do a cylinder balance test first. You should find one obvious cylinder not firing. Then examine its plug and plug wire. You might just have a bad plug.
gotcha
i've never heard of this tester .... how do u use it? (sorry for a dumb q but...)
It will probably have instructions. It's just a special test light. It backprobes the injector's electrical connector. The injector has constant accessory power and the ground is pulsed to it. This is the same way power to your ignition coil is delivered.
PROBLEM SOLVED!!!
i pulled out all the spark plugs n seafoamed the car...n its all mint now
the plugs were black n completely soaked in gas n black sludge(which i really dont know what it is)
THANKS FOR EVERYTHING GUYS !!!
