Wow, I wouldnt have expected some of what you're seeing.
I like to bleed the system with it open - that allows air to purge much easier.
If it cools off once up to speed, check the fan more - it might not be pulling as much air as it should.
If it run at 215 all the time and all else is ruled out (air issues, stat issues, etc), that indicates the radiator cant reject enough heat.
Good luck.
Good luck.
