  • SN95 4.6L Mustang Tech
X-Pipe installed, now issues
  • Thread starter Thread starter thomas91169
  • Start date Start date Jan 21, 2007
First Prev 2 of 2
T
thomas91169
I'd donkey punch my sister.
Aug 19, 2005
Modesto, CA
Jan 23, 2007
#21
  • Jan 23, 2007
  • #21
ok well i pulled the codes
P0155 - o2 Heater Circuit (Bank2 Sensor1)
P1151 - Lack of H02S21 Switches - Sensor indicates Lean (See P2197)
but i decided i should RTFM (Read The Fawking Manual) and i have do turn everything in the OBDII menu to off (well, except for EGR) thats related to the downstream o2's. I just had the option labeled OBDII MIL turned on.
well see how she does tomorrow.
d98gt
4,505
59
204
SE Texas
Jan 23, 2007
#22
  • Jan 23, 2007
  • #22
I seem to run extremely rich with my pipe. My xcal2 will be here this weekend so hopefully i'll be able to fix that.
I am currently using a vin locked (to someone elses car) superchips micro tuner to just read/clear the DTCs, though it comes back after a day or two. Am I going to have this problem with the xcal?
topless98gt
Adhesive Feces
Mar 31, 2005
182
Arlington, TX
Jan 23, 2007
#23
  • Jan 23, 2007
  • #23
With the xcal, you can completely disable the downstream O2 sensors. That way, it won't read any data into the computer, won't throw any codes, and then you can tune your car's air/fuel ratio as you see fit.
EDIT: Why not just spend the extra $$ and get the LiveWire? I will be getting one someday when they are finally available!
T
thomas91169
Aug 19, 2005
Modesto, CA
Jan 23, 2007
#24
  • Jan 23, 2007
  • #24
are you running a catless midpipe? how do you know its rich, other than how much more exhaust you smell?
the downstream o2's serve no purpose in fuel delivery or how the ecu changes its parameters, they are 100% for OBDII emissions purposes and just there to check if the catalytics are in place and working or not.
BTW, my SES has not returned during the entire drive to work thismorning, just goes to show sometimes reading the manual helps.
d98gt
4,505
59
204
SE Texas
Jan 23, 2007
#25
  • Jan 23, 2007
  • #25
Well my current pipe actually does have cats, though it's a custom pipe that I got for a few dollars so I guess I shouldn't whine about it much.
As for buying the livewire, I'm getting a xcal2 + mac pipe and another item for $180. Can't pass that up
fast97gt
1,082
north carolina
Jan 23, 2007
#26
  • Jan 23, 2007
  • #26
umm i have mil elims on my ride and i do have catless bassani o/r x-pipe never had a prob. but i herd that the comp. still receives signals from the o2 sensors w/ the elims on or hooked up and the reason for the mils is that there suppost to be resistors and the comp. reads the signals from the rear o2 sensors at like .5 a volt less than the fronts making the comp. think that the car is runnin perfect but your code po155 sounds like a bad o2 sensor on the pass. side front sensor if it were your rear or downstream sensors the code explination should read somethin like catalyst insufficiency bank 1 and 2 sensors 2
T
thomas91169
Aug 19, 2005
Modesto, CA
Jan 24, 2007
#27
  • Jan 24, 2007
  • #27
i dont know, but i went through and did all the necessary changes to the tune diablo recommended to do when using a catless midpipe to eradicate the CEL and ive put 30 miles on it and it hasnt popped up, as compared to getting around the corner and it popping up before the tune change.
and yes, the in-line MIL's are supposed to still allow a signal to the ecu, if they didnt, it would be the same as just disconnecting the rear o2's and it would pull a "Rear o2 Sensors Non-Existent" code anyways.
First Prev 2 of 2
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
  • Gulftown980x
  • Jul 29, 2026
squeak93
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
