X Vs H Pipe
  • Thread starter Thread starter Ts1lightning63
  • Start date Start date Jul 22, 2017
1 of 2 Next Last
T
Ts1lightning63
39
Canfield
Jul 22, 2017
  • Jul 22, 2017
From what I have read is that the 2004 GT has no low end torque and the H pipe would be better than the X pipe for that reason. Should I be concerned if I pick H over X? When I am done building this car it will only be street driven with a slightly build.
imp
Mustang Master
Jul 13, 2017
531
105
83
Jul 22, 2017
  • Jul 22, 2017
@Ts1lightning63
In my mind, it would be more a decision based on room available.... imp
robertsa
Well-Known Member
Apr 22, 2017
159
44
58
San Antonio
Jul 22, 2017
  • Jul 22, 2017
It's a decision based on personal preference. It's going to change the sound and that's about it. Get whichever you prefer the sound of. You aren't going to feel any difference in the go pedal between the x and h pipe.
Reactions: imp
Neuron
5 Year Member
Nov 6, 2016
859
192
93
Jul 22, 2017
  • Jul 22, 2017
Plenty of torque when you put the proper gears in the rear.
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Jul 22, 2017
  • Jul 22, 2017
Engine masters just did a video on this. The x won out by 1hp across the powerband.
Decision is best made from which sound you like best.
Reactions: Ts1lightning63 and Mustang5L5
RyanBell
20
Jul 23, 2017
  • Jul 23, 2017
View: https://www.youtube.com/watch?v=fCio5K0WfHU&index=1&list=PLGvTvFzdMg_O2T3UdUEt5dIHutSOu7srE
T
Ts1lightning63
39
Canfield
Jul 23, 2017
  • Jul 23, 2017
What gears to you suggest for an automatic?
T
Ts1lightning63
39
Canfield
Jul 23, 2017
  • Jul 23, 2017
It is kind of hard to make a decision based on sound clips when it is based on sound.
robertsa
Well-Known Member
Apr 22, 2017
159
44
58
San Antonio
Jul 23, 2017
  • Jul 23, 2017
I don't know what your sentence means.
As for having no low end torque, it's a sports car, not a diesel tow rig. These cars are now 13+ years old; expect it's going to need some freshening up and some power adders to catch up.
blackgt460
109
21
28
South East Pennsylvania
Jul 23, 2017
#10
  • Jul 23, 2017
  • #10
cat back will sound the same but the x will have more a a raspy perhaps higher pitch where the h has more of the deeper old school rumble
Reactions: Nater_Potater
T
Ts1lightning63
39
Canfield
Jul 24, 2017
#11
  • Jul 24, 2017
  • #11
I added a cold air intake, mufflers and a tune. I plan on adding gears, throttle body, high flow cats with x pipe,stage 1 cam, shorty headers and a new tune. Are there any other low cost upgrades you can suggest? What order would you install these since they will be done over time while the car is driven? The car does not need freshened up since it only has 3k miles on it. Any advice would be appreciated.
robertsa
Well-Known Member
Apr 22, 2017
159
44
58
San Antonio
Jul 24, 2017
#12
  • Jul 24, 2017
  • #12
My equation on these cars always starts with forced induction, turbos if you can afford it and supercharger if you want a lower cost alternative. I don't bother with all the little mods because they don't have the bang for the buck with the 4.6. A factory 5.0 can make tons of power over stock with aftermarket heads, cam, intake and exhaust because they were so corked up from the factory. The 4.6 wasn't that bad. My 5.0 Coyote doesn't even respond to CAI and exhaust mods because the factory stuff flows so well. All the "cheap" mods aren't cheap when you add up all the money you spend. I'm a big proponent of saving your money to get something that'll make a real difference while maintaining streetability, reliability, and fuel economy; forced induction does all of those things.
T
Ts1lightning63
39
Canfield
Jul 24, 2017
#13
  • Jul 24, 2017
  • #13
Thanks for the input, but I really didn't want to spend $5000 all st one time.
robertsa
Well-Known Member
Apr 22, 2017
159
44
58
San Antonio
Jul 24, 2017
#14
  • Jul 24, 2017
  • #14
That's fine. I deal with several budgets, my own and at work. The "I don't want to spend $XY all at once" but are willing to spend $XY over the course of a year or two thing doesn't make much sense to me. I prefer to save longer to get the better option.
To each their own though. Good luck with your build and keep us informed.
blackgt460
109
21
28
Jul 25, 2017
#15
  • Jul 25, 2017
  • #15
For me a new edge 4.6 has plenty worth it low budget mods that the car will respond to and many of the little mods stay even with forced induction down the road. Adding to your above mods I'd suggest underdrive pullies and an aluminum driveshaft. $500 for both brand new and a simple install especially the driveshaft as some don't have tools for the UDPs. The new driveshaft will also help clean up a lot of that 13 year old drive line clunk. From there some suspension work in the form of at least upper and lower control arms and you should have a decent bolt on car that gets to power to the ground properly. If you're doing the work to add headers and mid pipe I'd consider long tubes.
BeastsNMonsters
39
East Texas
Jul 25, 2017
#16
  • Jul 25, 2017
  • #16
For the mod motors, and most V8's 3.73 gears are a good choice for a balance between low and high end performance. Numerically higher are preferred for drag applications, and numerically lower for road courses with large straights. As to the H/X problem, the H is going to be easier to install and will have a sound characteristic more in line with the heritage of the car. As the new edge Stangs are still solid axle cars for the most part, I vote H pipe. Once you get into independent rear suspensions, you leave the muscle category and head into the true sports category.
SVT94GT
17
Va
Jul 26, 2017
#17
  • Jul 26, 2017
  • #17
I have SLP Long tubes, BBK Off road h pipe and SLP catback with resonators, but I'm gonna put some flowmaster 44 mufflers on to quite it down a bit. It'll still be loud though, those long tubes are nasty and make the car sound amazing. H pipe gives you the classic mustang sound, x pipe will give yoh a raspy angry sound. My setup sound unique all on it's on because it's super loud and it sounds really damn good because of the h pipe
Neuron
5 Year Member
Nov 6, 2016
859
192
93
Jul 26, 2017
#18
  • Jul 26, 2017
  • #18
3.73's and add a transmission cooler to be on the safe side.
Reactions: BeastsNMonsters and Ts1lightning63
BeastsNMonsters
39
East Texas
Jul 27, 2017
#19
  • Jul 27, 2017
  • #19
I agree with the transmission cooler
Boostedpimp
20+ Year Stangneter
May 8, 2003
1,451
493
154
NJ
Jul 27, 2017
#20
  • Jul 27, 2017
  • #20
I've had both and prefer the x
1 of 2 Next Last
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Fox BBK X-pipe replacement Cat?
  • TIGGER
  • Aug 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 26, 2025
AeroCoupe
J
Lost low end torque
  • JJ's90fox
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 5, 2025
Methodical
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
