V3 Almost!
If you hear it out of the intake, oil filler then it is either a bad intake valve- If you have a bad intake gasket check around the perimiter of the lower intake as well by squirting some soapy water and looking for bubbles or hissing noise on the cylinder you are doing the test on
If you hear it out of an adjacent cylinder spark plug hole or see bubbles in the radiator then most likely a HG or cracked block
If you hear it whistling out the tailpipe then most likely exhaust valve
No air heard leaking but you see a leakdown of 20% or more- bad rings,cylinders worn
Normal to see up to 15% leakdown on a used street motor. What you dont want to see is a huge variance between cylinders.
i have one more cylinder to do!?....and if i hear nothing?....so far no leaks,no bubbles,they all hold steady at 84-85 with 90 psi....thanks for info!
All good news then. check around the intake for a leak spraying soapy water or penetrating oil- non flammable- or use a smoke machine to see if their is a leak. You may have an intake gasket that broke where the head and intake meet- especially if its the cheap 1250 print o seal ones.
ok....so all check out at 84-85psi....im guessing its intake leak into oil galley right!!!....only time i heard somthing was when air pushed cylinder out of top dead....re did it and its was 84 like the rest
I'm going to guess- the intake gasket shifted under boost- get a set of 1250S3 or 1262S3 depending on your port size. They have the steel rings around the ports. Use a bit of camel snot to keep the gaskets in place when you lay the head down and put a nice 1/4 bead of right stuff on the front and back china rails- let them set up for a few minutes. Cut some long threaded rod and put one in each corner where the manifold goes down into the head as a guide When you lay down the intake just finger tight all the intake bolts and then snug them up in 3 phases- 5,15,22 lb ft torque and let it sit for a few hours. Then come back and retorque all the bolts. Then you can put the upper on.
ok i took the manifold off,didnt see a definitive spot where or if it was leaking,i did notice that the gasket came off real easy around the water ports,and hard to tell but it seemed to be wet behind also?....gona take a few pics in a few mins to post
@mikestang63 this is felpro 1262s-3?....am i ok to use this?
