[email protected] Im sure. Going to rpm pretty good might see 7k rpm( you're going to need a looser converter and more rear gear). You did tell them the entire combo right?
Need some seriously dished Pistons or some big chambers to NOT have 10:1 cr with a 393 build. Lol advertised duration...it is a custom grind. I'm sure they took all the pertinent info needed I would expect at least 230's [email protected] and more likely over 240 with at least 10.5:1cr. Op might see 550 flywheel hp and close to 500 ft lbs torque.
