Hi all, new to the forums but I’m in great need of assistance.
Picked up a 95 5.0 and I have this huge drain on my battery with the key in the ‘run’ position. Not in any other position. Also it’s with the car off, car isn’t running right now because of a fuel pump issue but that’s besides the point....started pulling fuses with the key in the run position and the draw finally goes away with 2 of the 3 ignition fuses pulled out, it has to be both of them, I’ve tried just one and it’s still there. The three fuses are all side by side, it’s the two outer ones that when pulled the draw goes away, the middle one doesn’t seem to have an affect on the draw.. what I have done is replace the alternator and CCRM because they were both done for, also the draw is still present with both of those components disconnected, I’ve looked around online and no one has seemed to have the same problem as me...please help!
