TwinTurbo93 said:I just use straight water, I live in Florida and the car is an occasional driver. There is also nothing harder to clean off the dragstrip than antifreeze so I know if anything ever happens and I spill some water on the track everyone won't have to wait for hours to get it cleaned up. I don't think it really matters what you use though, I would imagine that one is just as good as another.
cardudeusa said:Gm started using the Dex Cool because of the high energy ignition.
BlackFox5.0 said:I thought that they use it because it lasts longer. I read a sticker on the overflow bottle on some GM, and it said it should be changed after 5 years, or 150,000 miles. It aslo said something about it lasting longer than conventional antifreeze![]()
I am using PRESTONE AF2000 EXTENDED LIFE ANTIFREEZE . You would be hard pressed to find any better antifreeze products in the industry than those made by Prestone. The company name is so strong when it comes to coolant for your vehicle that the name itself is almost synonymous with antifreeze. This is a great product that will do a nice job cooling your engine even under the most extreme conditions . One of the best things about this product is how well it protects your cooling system from corrosion. With its built-in “cor-guard” technology it actually puts a protective layer of coating over you somewhat sensitive cooling system metals to keep them from breaking down under use.
